Draining the oil filter - tubing size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thundjet, Aug 1, 2012.
  1. Aug 1, 2012 at 10:21 AM
    Thundjet
    Thundjet [OP] Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    What size tubing do you need to put on that nipple under the oil filter holder so you can drain it directly to the pan?
  2. Aug 1, 2012 at 10:27 AM
    legga400
    legga400 Active Member
    Massachusetts
    TRD Sport
    working on it...
    5/16 vinyl tubing I believe... 4 and 1/2 ft should be good. bought mine at Lowes for a buck 50
    wi_taco and Bearcat_101_NE like this.
  3. Aug 1, 2012 at 10:30 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Wow, $50! I just hold a plastic cup underneath it.
  4. Aug 1, 2012 at 10:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Reading comprehension is not your strong suit... :rolleyes: He said $1.50 (a buck 50).
    I just use a 20 oz soda bottle. It wedges underneath the drain plug quite nicely.
    ToyoTaco25 likes this.
  5. Aug 1, 2012 at 11:21 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    ha, no it isn't but a plastic cup is like 20 for a dollar. :eek:
  6. Aug 1, 2012 at 11:25 AM
    Pugga
    Massachusetts
    Sorry, I had to throw a jab at that one :D
    I hear ya, I've been reusing the same Pepsi bottle for years now. The 20 oz bottles wedge in nicely under the drain plug and I can't remember what's below it to support the bottom but it's a hands-free operation.
    Bearcat_101_NE likes this.
  7. Aug 1, 2012 at 11:35 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I speed read at times and get mild dyslexic. I believe the alternator is below the oil filter.
  8. Aug 7, 2012 at 1:25 PM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    some kind of pulley ... i use a bottle as well for the past so many years.
  9. Aug 7, 2012 at 2:59 PM
    jdm.obp
    jdm.obp Well-Known Member
    561, FL
    3" Pro Comp, 5% all around, Antenna X shorty, Debadged
    wouldn't it be messier if you unplug it and plugged the plastic tubing in there? I also use the bottle method and not one drop has been missed.
  10. Aug 7, 2012 at 3:02 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    i used an empty seafoam can :)
    r3c0il likes this.
  11. Aug 7, 2012 at 3:04 PM
    Larry
    Larry CARL
    CARL
    empty water bottle works perfect.
  12. Aug 7, 2012 at 3:09 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    It's a permanent install useing a hose clamp. After it drains i cap off the end with a plastic plug...never had one drop of oil on the driveway. I've used the bottle method...the tube wins hands down!
    Chuy likes this.
  13. Aug 7, 2012 at 3:16 PM
    Larry
    Larry CARL
    CARL
    I'd have to disagree.
    Why have the tube there, especially perminate? when you can remove the little plug...place bottle...change filter...let the small amount of oil go into the bottle...clean filter scupper...replace plug...empty bottle...dispose bottle.
    clean...easy...done.
  14. Aug 7, 2012 at 3:21 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this^^
    cap it and toss it in the box that goes to the hazmat collection center..zero fuss..
    hose? forget it..drink water, place under nipple, crack loose filter..let it drain. crawl under, and do the drain plug..reverse, put work glove over now drained and dry old filter..reverse. super easy..i wouldnt fuck with a hose.
    but it could work fine..more than one way to skin a cat.
  15. Aug 7, 2012 at 3:51 PM
    OffroadToy
    Have you ever even tried the hose method? Believe me...i've tried both and the hose is soo much less work. I've read alot of stories here where the bottles get left in place after the oil change and makes one hell of a mess...can't happen with the hose. With the hose you empty the drained oil from a pan...that's it. No need to remove the plug, find a bottle, place the bottle, replace plug, empty bottle, and dispose of bottle.
  16. Aug 7, 2012 at 4:00 PM
    Larry
    Larry CARL
    CARL
    yes
    I did the hose method my 1st Tacoma oil change. although I did not mount it perminate.
    it was a PITA. when done you're left with a hose filled with oil residue, that slowly leaks out into a can to be delt with later.
    I promise you...the bottle method is simplier and cleaner.
    and, if someone leaves the bottle in place after changing the oil...that individual probably should not be doing their own oil change to begin with.
    Eatpocky likes this.
  17. Aug 7, 2012 at 5:07 PM
    OffroadToy
    ^ Understandable, i wouldn't use the hose either if i had to take it off after every oil change...that just doesn't make sense.
  18. Aug 7, 2012 at 5:16 PM
    sprocketgti3
    sprocketgti3 Well-Known Member
    Todd
    Sacramento CA
    Prerunner TRD
    TRD Air box TRD Exhaust Rear Swaybar Undercover Bed Cover Additional D-Ring rails installed, refab of oem rails. Steel Side bed lock box. 1" lift kit. Stainless Brake Lines Frt D-ring tie downs 12 VDC power port in rear bed Reinforced tailgate structure DRL cutout switch.
    :burnrubber::burnrubber:Use a 5/16" fuel line hose(oil safe). Then after R2 the filter, spray down filter catch and hose with electronic or plastic safe cleaner. No muss no fuss & no driveway drips.
  19. Aug 8, 2012 at 7:02 AM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
    i would be uncomfortable leaving a permanent hose there. Bottl works just fine for me.
  20. Aug 8, 2012 at 7:25 AM
    Larry
    Larry CARL
    CARL
