Dreaded coolant leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Darksport, Mar 31, 2022.
  1. Mar 31, 2022 at 8:29 AM
    Darksport
    Darksport [OP] Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Hey guys. So my truck is currently at the dealer after I noticed dried pink coolant on my garage floor as well as my coolant tank was right below LOW. Used a creeper and a flashlight under the truck and low and behold I found the source. Way up at the back of the block behind the throttle body it seems to be crusting up real bad and starting to drip. From digging into the posts here I see it’s probably from the weld failing on the plastic coolant pipe. Took it into Toyota and they call me back 45min later telling me the tech can’t see anything and they don’t feel like the coolant level is out of their standards. I told them to check again, and that I have pictures of the leak. They call me back in 10min. letting me know that they have to take apart the throttle body to diagnose the issue properly because they still can’t see the leak and that I’ll most likely be on the hook for a bunch of labor. So I drove back to the dealer, got the manager, had them put the truck back up on the lift and located the leak within 5 seconds. The manager got a good look at it as well.
    So, after that long story, the truck is still there and the manager is figuring out what to do. He seemed like an understanding guy but it’s a dealership. They’re in the game to make money, not lose it. My question to you guys is 1.) has anyone ever had this happen and had it successfully replaced under warranty? I bought the Platinum Extended Warranty (I know I know) and am hoping that will cover my ass.
    2.) If they don’t cover it, I’d probably do it myself. So has anyone here ever replaced that part themselves? Can a guy do it in his garage with basic tools? I haven’t been able to find a write up anywhere regarding this.
    Thanks for reading and thanks for any help.
    asuchemist likes this.
  2. Mar 31, 2022 at 8:33 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I’d definitely be trying like hell to get them to replace it, especially if u paid for an extended warranty. I’ve seen dealers try to get out of it tho.
    @Jowett has some experience diggin around back there, maybe he can shed some light.
    from what I’ve gathered you can get to it from under / behind the plenum.
  3. Mar 31, 2022 at 8:52 AM
    offthewallace
    offthewallace Member
    Langley
    2017 TRD OR AC
  4. Mar 31, 2022 at 8:53 AM
    Darksport
    Jake
    NE Ohio (Cleveland)
    Thanks for the response man. Just a total bummer especially seeing as this is becoming a more common problem. I’ll skim through that thread now.
  5. Mar 31, 2022 at 9:11 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    that warranty should cover it, let us know the $ amount it would have cost.
  6. Mar 31, 2022 at 9:33 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Hopefully they'll cover it.
    You should be able to get to it by removing the intake manifold. No special tools required, except maybe a topside creeper to make accessing that part of the engine easier.
    https://www.tacomaworld.com/threads/check-your-3-5l-coolant-pipe.531758/#post-17038973
    Darksport[QUOTED][OP] likes this.
  7. Mar 31, 2022 at 9:34 AM
    Darksport
    Jake
    NE Ohio (Cleveland)
    Update - Service manager went to run my Platinum Warranty and it came back saying it does NOT cover this repair/ part. He said he was baffled that even a Platinum Warranty didn’t cover it. Suggested I open a case with Toyota directly and fight the fight. Awesome.
  8. Mar 31, 2022 at 9:40 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    This is common on 2017 correct ?
  9. Mar 31, 2022 at 9:49 AM
    Darksport
    Jake
    NE Ohio (Cleveland)
    It’s definitely starting to look like that the more I google/ search on this issue.
    908tacoma[QUOTED] likes this.
  10. Mar 31, 2022 at 10:16 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Hope they do a recall to fix these. MY 19 looks ok for now @ 51K miles
    JustJon and Darksport[OP] like this.
  11. Mar 31, 2022 at 10:19 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    How many miles on your 17'?
  12. Mar 31, 2022 at 10:20 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    OP, how many miles on your truck?
  13. Mar 31, 2022 at 10:22 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    can you post the pics?
  14. Mar 31, 2022 at 10:32 AM
    Darksport
    Jake
    NE Ohio (Cleveland)
    A whopping 67,000 miles
    Junkhead likes this.
  15. Mar 31, 2022 at 10:34 AM
    Darksport
    Jake
    NE Ohio (Cleveland)
    They’re pretty bad but I’ll post here in a bit. Going to pick up my truck from the dealer now. I also opened up a case with Toyota about an hour ago. They have to do “research” into the matter then will get back to me.
  16. Mar 31, 2022 at 10:45 AM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Might be a good time to sell it to them. I doubt if the sales group will talk to service before making you an offer. Then they can fix it at their expense.
  17. Mar 31, 2022 at 10:48 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    While it may sound common, it's not. Toyota makes 250K Tacomas a year. Even 2400 a year is less than 1%.
    908tacoma, RustyGreen and Junkhead like this.
  18. Mar 31, 2022 at 10:48 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Condolences OP. I've been smelling coolant occasionally so I picked up an inspection camera to take a peak back there, been to scared to look lol.
    I've got a bad track record of pretty much experiencing 100% of the common problems on each vehicle I've owned. My last truck was a 2nd gen Frontier, that thing was a nightmare.
  19. Mar 31, 2022 at 10:50 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Great… I’m 10k away
  20. Mar 31, 2022 at 11:00 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I'm at 90k and haven't seen this. Don't get too worked up about it. Might not happen.
