Dreaded Misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lexiface, Sep 12, 2023.
  1. Sep 12, 2023 at 3:00 AM
    Lexiface
    Lexiface [OP] New Member
    Michael
    2012 Tacoma
    None
    Good morning, I'm new to this forum. Red seal technician of 35 years.
    My son bought a 2012 Tacoma 4.0.
    Drove it home. Next morning rough running and misfire. Engine light flashing.
    Of course my first reaction was with high kms just do regular maintenance. Plugs and coils. Erase code. Drive truck for quick drive. Seems to work fine. After a few drives, same thing. Misfire. Light flashing. Learned quickly of 2 trip logic and ecm shutting down cylinders as to not damage converter. Noticed whenever sitting over night first start would be rough. I suspect leaking injectors. They are cheap so I replaced them all. Like I said high mileage (300k)
    Erased codes. Truck started great. No misfire counts.
    Son took it up the road possibly 6kms. Filled with premium fuel.
    Returning home Engine light started flashing and of course misfire.
    I'm getting empty of ideas. Possibly low fuel pressure?
    Any feedback would be great. Thanks
  2. Sep 12, 2023 at 3:13 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Spark plug tube gaskets, maybe. Welcome to TW and good luck!
  3. Sep 12, 2023 at 3:27 AM
    Lexiface
    Michael
    2012 Tacoma
    None
    Not that.
    Steves104x4 likes this.
  4. Sep 12, 2023 at 4:13 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Head gasket leak.
    What did the spark plug look like? Wet?
    Coolant getting low?
    If it's the head gasket, get the copper flakes in a bottle.
    With the engine totally cold-
    Remove about a half gallon of coolant
    Mix the sealer with the half gallon of coolant. And put it back in the radiator.
    What the stuff does is clump up and melt together when it gets hot.
    The first place to get hot is usually the leak, so it clumps up there.
    I work on a lot of cars and people are generally idiots because they refuse to read the directions or understand how an engine works. These morons pour leak stop right into a hot radiator and then say "this product killed my car".
    Anyways, you get the point.
    Off topic, but the truck takes a few hundred miles to benefit from high octane fuel. After that, I can get maybe 20-30 more miles per tank from 93 compared to 87. Not exactly worth the price difference, but going 230mi is much better than going 200mi.
  5. Sep 12, 2023 at 5:45 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It runs rough on cold startup because a little bit if coolant leaking into the cylinder(s) overnight. It chokes on the coolant for a few seconds and then smooths out. I'll bet you have a gradual/slow loss of coolant too..
    Sounds like a head gasket leak
    TnShooter and Bishop84 like this.
