Dreaded oil pan leak on 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Apr 19, 2019.
  1. Apr 20, 2019 at 7:51 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I can call my toyoTech specialist I recently found locally next week if you want to get a quote for oil pan job.
    his rate is a bit less than the dealer shop and I believe he has my trucks best interest in mind
    its a bit far of a drive for you unless you are on your holiday to vacation in the Rockies!
    was your truck new or when you got it?
    If I had a big enough garage for a lift to be installed I would so that I could do the minor maintenance (fluid changes,etc) underneath like I did as a lubeTech with an open pit back when I was a teen
  2. Apr 20, 2019 at 8:36 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    If you mean my tacoma, no, it wasn't new. In need of a bit of love but not abused or trashed, you know. But if you meant the worktrucks, not new but not that old either. Both had always been well maintained.
    Ah yes, I'd love to have a lift me too.Maybe in the future when'ill move to the countryside. But for now, I know of a place where they have a bunch of lifts that you can rent for a few hours at a time to do some repairs on your car
    GQ7227[QUOTED] likes this.
  3. Apr 21, 2019 at 7:21 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    1500+ miles away :bikewhoops:
    I did post an ad here in the North East section to see if I might get lucky and find a Taco mechanic close to me
  4. Apr 22, 2019 at 9:06 AM
    vettehigh
    Jon
    Upstate, NY
    Tried 2 other mechanics I know, but one is too busy for anything right now and another told me it's Porsche season for him (he has no time). I have one other guy that I have to see next week. I did have a Tacoma tech that lived down my street and he did all my work, but he moved out of town last month :(
    GQ7227 likes this.
  5. Apr 22, 2019 at 9:51 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    have you had any front suspension, etc. work done it on before?
    If not it might be good idea to put some fresh parts on since they probably have it off anyways to get the pan
    would save on the labor cost :notsure:
  6. Apr 22, 2019 at 9:53 AM
    vettehigh
    Jon
    Upstate, NY
    Yes, new OEM lower ball joints/tie rods (both sides)
  7. Apr 22, 2019 at 9:59 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did that involve dropping suspension to get to those (i am not a mechanical whiz so i dunno!)
    in removing front diff to get to the pan, do you also have to undo suspension parts?
  8. Apr 22, 2019 at 10:05 AM
    vettehigh
    Jon
    Upstate, NY
    I think it's mostly just the diff and axles from what I read and was told
  9. Apr 22, 2019 at 10:07 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    lets ask @1997tacomav6
    have you had to change your oil pan/gasket ever?
    vettehigh[OP] likes this.
  10. Apr 23, 2019 at 8:40 AM
    vettehigh
    Jon
    Upstate, NY
    Found a Tacoma tech 20 minutes from me....all set for next week :thumbsup:
    Labor around $350
    GQ7227 likes this.
  11. Apr 24, 2019 at 12:00 PM
    vettehigh
    Jon
    Upstate, NY
    I received all my OEM parts today, one problem was the oil pan itself....it's scratched all over the bottom (on the outside) and you can see where the paint is missing in scratch spots. Was told that they come this was from Toyota without any protective covering:mad:
    I has them order me another one to see what shape that would be in
    GQ7227 likes this.
  12. Apr 24, 2019 at 9:42 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Go to store and buy a can of part cleaner and a can of “the right stuff” it’s literally called that. Clean the surface run a bead where it is leaking. Go about your life. It works
  13. Apr 24, 2019 at 10:37 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    yea they come shipped open.. i got 3 and all of them were scratched up good... best to just get some good paint and paint it before you put it on.. its e-coat anyway, it'll rust in a few winters
    Area51Runner likes this.
  14. Apr 25, 2019 at 4:48 AM
    vettehigh
    Jon
    Upstate, NY
    What about Por15? I have some in black left
    What about spraying it with bed liner??
  15. Apr 25, 2019 at 5:22 AM
    #35
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have a pic of what this pan looks like, I'm just curious about the scratching
    powder coat it white? make it :cool: match the exterior
  16. Apr 25, 2019 at 5:34 AM
    #36
    vettehigh
    Jon
    Upstate, NY
  17. Apr 25, 2019 at 5:35 AM
    #37
    GQ7227
    GQ7227 mw survivor
    J A Y
    looks like they stack those on a shelf in some warehouse like I stack dishes and pots in the cabinets!
    Dalandser and vettehigh[OP] like this.
  18. Apr 25, 2019 at 6:51 AM
    #38
    vettehigh
    Jon
    Upstate, NY
    Heading to my body man....he is painting a black car today so he said bring it down:thumbsup:
    GQ7227 likes this.
  19. Apr 25, 2019 at 7:04 AM
    #39
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I've good results painting oil pans using an Engine Enamel that requires baking for curing.
  20. Apr 25, 2019 at 8:04 AM
    #40
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    It depends what mechanic you go to there are some what would just shot a number and see it sticks, you should search a mechanic who know how to work with Toyota because they know few tricks. I asked the guy I learned to do everyhting to tacoma and the older pickups he said he would charge $200 to $250 for 4cly and only take hime few hours. Just find the right guy
