Dreaded P0420 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Feb 19, 2015.
  1. Feb 27, 2015 at 9:48 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Had the same problem randomly for 3 years. Messed my cat up and replaced it with a magna flow. Haven't had the code since then
  2. Feb 28, 2015 at 6:07 PM
    orangeoutlaw
    orangeoutlaw Well-Known Member
    NorCal
    2000 Taco ex cab
    2.5 sway-a-way coilovers, camburg 1" uniball uca's, Bilstien 7100's rear, Deaver j59 leafs, Solo Motorsports rear shock hoop relocation kit,Pro comp LA paz 16x8 matte black wheels with Toyo MT 305/70/16, 1.25" billet spacers, diff drop, Exedy stage 1 clutch, warn 9000, bent up bumpers, halo proj headlights, led tails and turns, snug-top, kicker comp 12, infinity kappa doors, kicker amps, painted frame, snug-top shell, yakima high roller bike racks
    I replaced rear o2 sensor and it fixed my p0420
  3. Mar 6, 2015 at 1:21 AM
    gtaber
    gtaber Member
    TX
    2000 PreRunner
    TRD super charger
    I've been dealing with this error code on my 2000 prerunner 3.4L for over 3/4 yrs now. Some times it goes off by its self. I can't tell any difference in performance if the CEL is on or off. I only worry about it once a year, my State/county does inspect emissions. I've discovered I can clear it with my ODB gadget (best $12 I ever spent) and Torque app, drive approx 200 miles and I can pass inspection, it will usually come back at around 500 miles. My cat was stolen in 2007, and I couldn't afford an OEM, so I bought a magna-flow, but it had to be welded in, and my flanges cut off. At the time it saved me over $600, and seemed worth it. The O2 sensors were spared, and are original ones from the factory. I haven't tried one of those, and probably won't until I can't get it inspected. I agree with Mr. Biscuits, clear it, see if it comes back, try the easy/cheap fixes, and if you don't have to worry about emissions for inspection, don't worry about it unless you can tell definite performance/operational issues related to it.
  4. Mar 6, 2015 at 5:45 PM
    Stretch815
    Stretch815 Member
    Stretch
    Chicagoland
    03 tacoma 4x4
  5. Mar 6, 2015 at 6:57 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Guess it was just a hiccup cause it hasn't come back on after I cleared it
  6. Mar 11, 2015 at 10:26 AM
    GMack52
    GMack52 Well-Known Member
    Garrett
    Clermont, FL
    2001 Tacoma SR5 TRD
    bed liner, that's it for now
    Ok. I got that code coming home from school today.
    This past weekend my truck went in for a much overdue tune up and they replaced the O2 sensor Idk if it was front or rear, and cleaned off my dirt-encrusted MAF sensor which had been throwing a P0171 code for months. I reset that code and it hasn't come back but now this one has come up. I also replaced my spark plugs and a vacuum hose.
    It pretty much sounds like I've screwed with everything that could cause this code very recently. What should I do?
    Also, what does this code means in terms of safety to drive and will it hurt my taco?
    It's a 2001 TRD with a K&N air filter if that helps
  7. Mar 11, 2015 at 12:11 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    It won't hurt the truck. It just means that the catalytic converter is working at below 95% efficiencyou, which means that you're polluting a little more lol. I would say just erase it and see if it pops up again. That's what I did for mine. Hasn't come back yet
  8. Mar 11, 2015 at 12:14 PM
    GMack52
    Garrett
    Clermont, FL
    2001 Tacoma SR5 TRD
    Awesome. As long as it doesn't hurt my truck I'm cool with it.
  9. Apr 10, 2015 at 11:22 AM
    Davie Boy
    Davie Boy Member
    Valencia, CA
    '99 Tacoma SR5, 2.4
    I recently had the same issue with my '99 4-banger. I've read through several previous posts on the subject. From what I've gathered, the code could mean an issue with:
    • one of the sensors
    • the cat
    • an exhaust leak
    • poor quality fuel
    One post mentioned using a specific fuel additive which is supposed to clean the cat. I couldn't find it at my local auto parts store so I tried this stuff called Guaranteed To Pass. It says it cleans the who fuel system and emissions-related equipment. Within 50 miles, my CEL turned off. Who knows how long it'll last, but for $12 I think it's a great place to start.
