Dremel Kits For Satoshi??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TEX357, Apr 25, 2009.
  1. Apr 25, 2009 at 3:11 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    I looked everywhere for the Dremel Kits here locally and they have them but for like 50 bucks (CHEAPEST) and i know a couple of yall discussed before about finding some for about 10$ that werent too good but got the job done? any of yall know what brand these are and what I'm talking about?:confused:
  2. Apr 25, 2009 at 3:14 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
  3. Apr 25, 2009 at 3:25 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    Thanks man!
  4. Apr 25, 2009 at 3:30 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    no problem!
  5. Apr 25, 2009 at 3:49 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I got mine at harborfrieght for 8.99 does the job!
  6. Apr 25, 2009 at 4:12 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    Is harborfrieght like a north us brand or what? Never seen it down here
  7. Apr 25, 2009 at 6:32 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    harbor freight is all over the southeast
  8. Apr 25, 2009 at 6:42 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    I just used a Dremel tool today to cut the crossbars from my grill for the Satoshi mod. I wouldn't recommend using a Dremel tool for this project unless you have the patience of a saint.
    It would have been much easier to use a sawsall or hacksaw, neither of which I had readily available today.
    The only way to accomplish this task with a Dremel, is to use the drill bit and either drill individual holes, which takes forever... or start a hole and use the drill bit as a router, which does a better job of melting the plastic rather than cutting it. It worked, but it was frustrating and took forever.
  9. Apr 26, 2009 at 2:39 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    so is there a way to install a satoshi grill while keeping the option of putting the stock grill back on
  10. Apr 26, 2009 at 2:49 PM
    The_Hodge
    SC
    if u wanna rip back out the fiberglass you put in and then fiberglass the stock crossbars back in. would be a royal pain in the ass i think
  11. Apr 26, 2009 at 2:55 PM
    Burgman
    Stephen
    Ric VA
    ill take that as a no
  12. Apr 26, 2009 at 3:14 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    satoshi is a one way option. no going back. I do recommend using a dremel for doing the satoshi. For just cutting out the stock grill center, yeah it was a little tedious, but the dremel is necessary for the fine cuts to keep you from sanding 10x longer.
  13. Apr 26, 2009 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    In my Dremmel set, I have a rotory cutting tool, Similar to a Roto Zip bit. It made very short work of the grill.
  14. Apr 26, 2009 at 4:43 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    i started with the dremel, then realized it was a pain. so i used a hacksaw blade which made quick work of getting the grill out. then once it was out used the dremel to cut/grind the remaining plastic flush were you will fill in with fiberglass. worked good for me.
