Dremel Recommendations
Discussion in 'Technical Chat' started by Jarlaxle73, Mar 30, 2019.
  1. Mar 30, 2019 at 1:43 PM
    Jarlaxle73
    Jarlaxle73 [OP] Well-Known Member
    Clinton
    Newport, Oregon
    2019 Crew Cab TRD Off Road
    285/70/17 17 in TRD PRO wheels
    Could anyone recommend the best Dremel to use to cut the plastic on the front bumper area for the installation of a SSO bumper? Or is there a better tool to use? Thanks!
  2. Mar 30, 2019 at 1:55 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I haven't installed one but I would think a 4in cutoff wheel would leave a straighter line on the main parts? If you get a dremel get the larger 1.5in wheel and the one that's variable speed, not just 2 speed. You will have better control. The cut is covered so it doesn't have to be perfect.
    Jarlaxle73[OP] likes this.
  3. Mar 30, 2019 at 2:05 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Have you tried just using a utility knife?
    Or a sawzall?:devil:
  4. Mar 30, 2019 at 2:36 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    Thanks! It does get covered up, but I am still a little apprehensive about cutting on a brand new truck!
  5. Mar 30, 2019 at 2:37 PM
    s.e.charles
    s.e.charles Well-Known Member
    I would use the least aggressive tool possible to minimize any drifting. drill points around the perimeter to define the area of carnage. score all, 32 tooth hacksaw blade, sharp utility knife blade in a specific pattern. maybe clean up with a drum sander bit in the Dremel after the hole is cut out.
    not sure high rpms & low torque is what you're looking for.
  6. Mar 30, 2019 at 2:40 PM
    20tacoma17
    2017 DCLB Sport AT
    Same here. That's why I dont have one yet and it's over 2yrs old now. :goingcrazy:
  7. Mar 30, 2019 at 2:40 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    I am looking at the Dremel 4000 at the moment. It is variable speed and comes with a reinforced cut off wheel.
  8. Mar 30, 2019 at 2:43 PM
    20tacoma17
    2017 DCLB Sport AT
    That's one of the better ones.
  9. Mar 30, 2019 at 2:56 PM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    Don't make the same mistake I did and buy the Harbor Freight one. That thing was useless. Not enough power to get through the plastic bumper. I ended up southern engineering the cutting blade from it to use in my drill. That did the trick.
  10. Mar 30, 2019 at 2:58 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    On top of all of this great info. Tape off the peremeter of your cuts to protect the paint! Acid free masking tape is best.
    Jarlaxle73[OP] and 20tacoma17 like this.
  11. Mar 30, 2019 at 3:39 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    Thank you all for the advice!
    20tacoma17 likes this.
  12. Mar 30, 2019 at 4:34 PM
    s.e.charles
    wear glasses! some guys saturate the wheel with superglue and let it dry to help with the shatter effect.
  13. Mar 30, 2019 at 4:41 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    Definitely! I have safety glasses just for that purpose.
  14. Mar 30, 2019 at 4:46 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Really? I have owned the red Chicago electric from harbor freight for years... cut through metal...plastic whatever I ask it to...
    I do use the real dremel wheels and bits for it (from Lowe's or hd) But it's been great. Variable speed electric model....
  15. Mar 30, 2019 at 4:50 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    If you have either one of these they will work just fine
  16. Mar 30, 2019 at 5:48 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    I do have both, but I worry about the precision of the cut.
  17. Mar 30, 2019 at 5:51 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    the bumper covers most of what you cut. If you do mess up you can always just use some edge trim.
    Heck I did this with those tools over a year ago and haven't covered it up yet
  18. Mar 30, 2019 at 6:03 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    You will be fine just take your time and don't sike yourself out to much
  19. Mar 30, 2019 at 6:05 PM
    taco_turco
    taco_turco Well-Known Member
    St. Augustine, FL, United States
    2019 TRD OR
    Always there will be variety tools, but it will come to the point of your skill. Use whatever tool you have, it's experience after all, save your money to buy more armor instead of buying a new tool. The worst case scenario, you might change your option for the bumper.
    Jarlaxle73[OP] and mynewtoy like this.
  20. Mar 31, 2019 at 12:19 PM
    Jarlaxle73
    Clinton
    Newport, Oregon
    A solid set of sliders and some skid plates are a top priority. Probably get them after the tires and before the bumper.
