Dried coolant around heater hose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvparadise, Apr 6, 2020.
  1. Apr 6, 2020 at 4:00 PM
    mvparadise
    mvparadise [OP] Well-Known Member
    2013 Toyota Crew cab 4x4
    Recently purchased a 2013 Toyota crew cab 4.0 auto. Noticed small amount of dried coolant around the back heater hose connecting to the motor or block. Looks old and ash like. No signs of new drips or leaks. Does not overheat and seems to run normal. Should I be concerned. 105k miles. Dried coolant around reservoir wiped it clean and moved clamp. Level seems to hold.
  2. Apr 6, 2020 at 4:05 PM
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    If it doesn't overheat and coolant levels stay solid I wouldn't worry about it. Wipe it off and check whenever
    Welcome to TW!
    mvparadise[OP] and whatstcp like this.
  3. Apr 6, 2020 at 4:14 PM
    mvparadise
    No does not overheat I drove it 400 miles home when purchased. Really like the new to me truck. Hoping to keep it forever. Just service the transmission last week.
    j_sav115 likes this.
  4. Apr 6, 2020 at 4:15 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Clean it off and tighten the clamp, no problem.
  5. Apr 6, 2020 at 4:28 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    Your good to go man, change fluids and wear parts at recommended intervals and it should go forever lol.
  6. Apr 6, 2020 at 4:44 PM
    mvparadise
    Thanks. Leaking coolant always a concern of mine. I will keep up on things. Glad to be part of this group!!! Cheers!!
  7. Apr 6, 2020 at 5:15 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    :cheers:
  8. Apr 6, 2020 at 5:51 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I used to get paranoid and would add an extra worm clamp if there was room. Now, I would just clean it and check periodically.
