Drill holes in the bed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JFS, Sep 20, 2020.
  1. Sep 20, 2020 at 3:58 PM
    JFS
    JFS [OP] Member
    2003 2.4 Tacoma regular cab
    swapped bench for bucket seats, monstalinered the bed.
    Hi folks. My 2003 Tacoma has a pendaliner over-the-rail bedliner that's seen better days but is still more or less functional. I've been thinking of removing it and going with monstaliner or raptor, monstaliner because I could save a little with DIY, but I found someone who will do it with Raptor for $375, so I might go that way. (Opinions welcome on one or the other.) My issue is that 1.) the truck is jacked high in the back, apparently because it was used for haulage, so no matter how I park it collects water cab-side. (I've tried parking on ramps, and while that works, I'd rather not have to do it.)
    I took off the bedliner today. There's bare metal, but I see no real rust yet, thankfully. Also, I see no drain holes. Should I drill some before applying bedliner? Is there's a process to it, specific size, grommets, or just drill holes where they seem to drain clean underneath and move on? Thanks.
  2. Sep 20, 2020 at 4:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    There are drain holes. Find them in the front corners and clean them out.
    If you want them bigger, or more of them don't drill into the gas tank as more than one has done.
    Lower the rear if you don't need the height.
    Monstaliner.
    JFS[OP] and Tullie D like this.
  3. Sep 20, 2020 at 4:45 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Drain holes are already there like @Clearwater Bill said. In each corner where I have the screw driver in the pic below. You don't need to drill them out to make them bigger, just stick a screw driver in there to clean them out and you can bend the metal a little to enlarge them.
    JFS[OP] likes this.
  4. Sep 20, 2020 at 4:49 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    they sell bedliner at Tractor Supply thats really good tuff stuff at a goooood price
    for the do it yo selfer
    with Proper Prep a couple coats U can avoid rust
    JFS[QUOTED][OP] likes this.
  5. Sep 20, 2020 at 5:27 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Not saying it is not good, but personally, I would never go Rhino/Raptor/Monsta/X-liner or whatever it is called because if you eventually have any little crack or chip, moisture will get in and it will just fester with rust underneath the liner. Good luck removing that stuff to treat the rust, it's rock hard!
    Then there is people that say that plastic bedliners make the bed rust. Well, not at all. What makes the bed rust is all the crap that gets acccumulated underneath it over time. Remove it from time to time to clean up what has accumulated and do some touch ups if needed and your bed will never rust
    Both options have their advantages and disadvantages
    Wyoming09, Hamer95USA and JFS[OP] like this.
  6. Sep 20, 2020 at 5:30 PM
    ROAD DOG
    FEW
    not certain there is a bullet proof cure
    especially when its a work truck & U are hauling
    only U can determine cost reward vs to continue for the life left in the truck
    JFS[OP] likes this.
  7. Sep 20, 2020 at 8:51 PM
    JFS
    JFS [OP] Member
    Thank you all so much. I haven't figured out a plan yet, but now I have a lot more useful information. I'll go on a drain hole hunt, then take it from there. Tacomaworld comes through again. So glad I came here before taking a drill to it. That gas tank mistake is all kinds of awful, thankfully avoided.
    0xDEADBEEF likes this.
  8. Sep 21, 2020 at 3:31 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    my 03 DC has 2 large rubber grommets that pop out for drainage.
  9. Sep 21, 2020 at 5:22 AM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    I had my bed Rhino lined right after purchase in '04 The installer took a round chisel and just punched a 1/2" hole in the front corners. I just about had a stroke watching him do it.
    Fast forward 16 years and no problems with bed rust or blockage.
    JFS[QUOTED][OP] and cornbread_wy like this.
