drill into bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Apr 2, 2012.
  1. Apr 2, 2012 at 4:37 AM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    Since the bed is composite, can you drill into it? Also if I want to attach something to the side what type of screw should I use? JUst want to attach some fishing rod holders.
  2. Apr 2, 2012 at 4:39 AM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    Yes you can drill into it. Regular nut and bolt if it is somewhere you can get to the otherside, self tapping screw, or plusnuts.
  3. Apr 2, 2012 at 4:40 AM
    JPDud2
    JPDud2 Active Member
    Little Rock, AR
    2011 Debagged TRD Sport 4x4
    Stereo: 2 JL 8W3v3 subs 2 JL 6.5 C5 coax 2 JL 6.5 C5 components JL HD 900.5 amp Pioneer AVH 2400 Exterior: Access bed cover TRD skid plate Painted valance Painted fog sleeves 6000k HID headlamps 6000K HID fogs Avid rock sliders 3" SST lift Terra Grappler 285/70r/17
    I would still use a metal screw. Also--i have that bed cover---looks and works great. But don't go with katskin. Find a local upholster. I got my entire truck wrapped in leather (including arm rests) for $1000. and its the real deal instead of leather covers.
  4. Apr 2, 2012 at 5:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You should be able to thru bolt your mounts if you put your mounts within reach of the cubby holes. You could also remove the storage boxes to gain access behind without having to get up underneath the truck.
  5. Apr 2, 2012 at 5:32 AM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    sub'd to see the finished product!!!
  6. Apr 2, 2012 at 5:50 AM
    Squirrellydw
    Thanks guys. Might be a a week or two till its done. Still planing it out.
  7. Apr 2, 2012 at 5:56 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    just for your own sake, dont make the mistake i did lol. i drilledinto the front left corner of the bed(closest to the driver side of the cab) and i couldnt get my hand above the gas tank to put the nut on the bolt.
    Stewzz likes this.
  8. Apr 2, 2012 at 6:07 AM
    Squirrellydw
    Thanks for the info
