Drilled hole in air filter box...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ezriderga, Aug 6, 2011.
  1. Aug 6, 2011 at 6:23 AM
    Ezriderga
    Ezriderga [OP] Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    I saw where someone posted they cut the entire front of the airbox out. I took a more conservative approach.
    I Drilled a 1 5/8 hole in the front of the airbox right in the center of the depression. Did not remove the secondary filter.
    After doing so, I noticed the RPM at idle cold was about 200 higher. Also noticed the lag in acceleration that I was experiencing is gone.
    I have filled up my fuel tank and am going to check mileage. It really is a moot point whether it's better or worse. I'm just curious. I am most pleased that the lag is gone.
  2. Aug 6, 2011 at 8:16 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Around here they call it a deck plate mod.
  3. Aug 6, 2011 at 8:19 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    The deckplate mod has an actual deckplate in it. And its only beneficial to 1st gens.
  4. Aug 6, 2011 at 8:55 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Interesting
  5. Aug 6, 2011 at 8:56 AM
    prerunner32
    prerunner32 TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Agreed... Sub'd
  6. Aug 6, 2011 at 9:01 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Is this an easier way than say like a K&N ?? Just curious. What makes this more beneficial to 1st generations? 2nd gen. engineering solve this issue?
  7. Aug 6, 2011 at 9:08 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    You should disconnect your neg battery terminal to help the ecu speed up the process of learning a new af ratio.
  8. Aug 6, 2011 at 9:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The only thing I can see this doing, is letting more warm air into the engine, giving a more lean condition (Warmer air has less O2, so the AFR is leaned out).
  9. Aug 6, 2011 at 9:26 AM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    so when more air is introduced to the intake does the cpu compensate by delivering more fuel to keep the programmed ratio of fuel and air?
  10. Aug 6, 2011 at 9:29 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Don't you mean less lean and more rich?
  11. Aug 6, 2011 at 9:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 1 5/8" hole isnt going to allow any more flow than the air box is already delivering. You can check this with a scan tool of your choice, and watch the MAF Gms./sec. air flow reading.
    No. Warmer air = less O2. Less O2 = less fuel injected into the engine.
  12. Aug 6, 2011 at 9:36 AM
    cummins6speed
    But if you have less O2 and less fuel then you will still have the same AFR (provided the reduction in O2 and fuel are proportional
  13. Aug 6, 2011 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. The computer will adjust to keep the AFR's in check.
  14. Aug 6, 2011 at 9:39 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    in my engineering classes..i learned that most car motors have a choke point in the air supply system and it is rarely the air cleaner.
    on my old 911, i can take off the air filter and see zero benefit because the stupid air sensor plate is the restriction point.
    any added risk to suck water thru that opening?
  15. Aug 6, 2011 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. On a modern vehicle, that choke point is the Throttle body, although its sized according to the CC volume, and what the valves can flow.
