Drilled vs Slotted Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Nov 30, 2016.
  1. Nov 30, 2016 at 7:38 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I disagree. Those are the EBC sport dimpled/slotted rotors and they are the best bang for your buck rotor upgrade.
    The green stuff and yellow stuff EBC pads are high friction and will create lots if dust. But i have run both, and both stop considerably better than stock. Plus they handle the heat better.
    ydlee likes this.
  2. Dec 1, 2016 at 1:50 PM
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    EBC is way too dirty
    Rims get dusty fast and are a pain to clean
    Had them on for two months and then just pulled them, went back to OEM
    I threw them away, should have sold them.
  3. Dec 1, 2016 at 2:01 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Again, these are trucks. OEM rotors and pads are all you will need for street or dirt.
    hardground likes this.
  4. Dec 1, 2016 at 3:04 PM
    qfast817
    qfast817 Well-Known Member
    Q
    Fort Worth Texas
    Tacoma
    By stepping on the pedal....
  5. Dec 1, 2016 at 8:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So you used a scientific method. " It felt like ... "
    Stepping on the brake pedal isn't an accepted method of measurement.
  6. Dec 2, 2016 at 10:04 AM
    qfast817
    Q
    Fort Worth Texas
    Tacoma
    as long as it stops when I want it to I would think that's a good method of measurement.
