drilling in front sidewall truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Littleriver, Mar 11, 2025.
  1. Mar 11, 2025 at 6:05 PM
    Littleriver
    Littleriver [OP] Member
    yves
    i want to drill a small hole through my front side wall bed (between the cab and the truck bed) to run a #4 awg wire from my car battery to my charge controller. Can you see a problem of doing it? At first i wanted to go through the cubby on the driver side but my cable will be to short. Is it better if i drill it under the bed instead? i will use a grommets and silicone caulking to seal it.
    thanks for helping
  2. Mar 11, 2025 at 8:06 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    You'll be plenty fine.
  3. Mar 12, 2025 at 12:02 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Some do no drilling and put the wire through the bed crack between the left bedrail and the front bed rail.
