Drilling into bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by udrunk2002, Jul 3, 2020.
  1. May 8, 2025 at 12:15 PM
    #41
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Everything causes cancer in California.
  2. May 8, 2025 at 3:20 PM
    #42
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Just so you know they make rivet nuts specific for varying thickness (not a 1 fits all). But I agree jack nut probably holds better in the material… and I kinda dislike jack nuts. It was included to use for rear grab handles in sheet metal but I ended up getting the measurements of the hole used and ordered the right rivet nut.
  3. May 8, 2025 at 3:48 PM
    #43
    forana
    Kaneohe, Hawaii
    Rivets also work best when a very precise sized hole is drilled. Probably my fault but it was very difficult to drill a clean hole in the composite material. Best for metal.
    Either way, using nuts and bolts worked fine for me.
  4. May 8, 2025 at 4:10 PM
    #44
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The factory backs the composite up with a bit of steel on the backside. See the side D-rings for an example.
  5. May 18, 2025 at 10:08 AM
    #45
    MtnAltitude
    MtnAltitude AKA: Grump-a-saurus
    Colorado Mtns
    2020 Tacoma TRD Pro AG, 1971 FJ40 - all MT
    Has anyone tried using a Rivet Nut to mount an electrical component on the back of the bed (through the composit material)? If so did you use a specific type of rivet nut?
  6. May 18, 2025 at 10:17 AM
    #46
    forana
    Kaneohe, Hawaii
    Uhh, did you read this thread?
  7. May 18, 2025 at 10:23 AM
    #47
    MtnAltitude
    Colorado Mtns
    I have - I also read the referrel to the "Jack Nut" - not a fan. I want to use an actual Rivet Nut, my question is in reference to find one specific for plastic (composite) versus the Rivet Nuts I have with my Rivet Nut Tool. Sorry, I should have been clearer in my question
  8. May 18, 2025 at 10:28 AM
    #48
    Toycoma2021
    Just to be absolutely clear.
    Whatever you do follow the lead of Toyota and back the rivet nut up with some steel, just like the existing attachments for the D-Rings. No need to reinvent the wheel.
    McMaster has a good selection: some even specified for composite materials.
    rivet nuts | McMaster-Carr
    MtnAltitude[QUOTED] likes this.
