Drilling through the frame....need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Jun 21, 2017.
  1. Jun 21, 2017 at 2:41 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Why are you even messing with that? Weld them on. Every advantage and no disadvantage
    Mully likes this.
  2. Jun 21, 2017 at 2:42 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I too used the cheap Harbor Freight step drill bit to drill through my frame.
    OP, there is a trick to drilling your frame. Mark the spot by pre-drilling with 1/8" bit.
    Use a step drill bit. Make sure to tape off the bit to hole size you want to stop at. Use medium speed. Higher RPM just heats up the bit. Use a lubricant spray while drilling.
    The most important trick, use the jack method. The jack provides the pressure and saves your arms from fatigue. You'd need some coordination to do this.
    And if you haven't already, make sure to line up the sliders first and hold with a jack then mark the holes. Much easier to drill without the sliders in the way.
  3. Jun 21, 2017 at 2:43 PM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Everytime I'm in a thread where somebody needs advice you are always here before any other vendors. Just want to say that doesnt go unnoticed. @Mobtown Offroad its great your always around to offer good advice on your product as well as others. Look forward to doing business with you guys.
    MotoEd, Nickel, 11Bguy and 2 others like this.
  4. Jun 21, 2017 at 2:45 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I found the frame easy to drill with this method. Use a new cobalt bit and some cutting oil. On the frame sides lean into the drill motor to maintain pressure, use a slow speed (you should get curls of metal, not chips) and occasionally dip the tip in the cutting oil. On the bottom of the frame follow the same process but use a floor jack to maintain pressure on the drill motor. The bottom holes went faster than the sides that way. If you need an angle drill for a tight location, Harbor Freight sells an inexpensive angle attachment that works fine for the number of holes required.
  5. Jun 21, 2017 at 2:50 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    This!!!
  6. Jun 21, 2017 at 2:50 PM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I wasn't aware of your business till now. I'd looked at CBI and Relentless only because they were suggested to me. They were either far too expensive or the lead time was outrageous.
    Definitely no getting curls...getting chips. Been leaning into it pretty hard. Maybe I need even more pressure.
  7. Jun 21, 2017 at 2:50 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You know, I was just thinking the same thing when I was reading the CCW thread and @Mobtown Offroad had a comment on there. I thought this guy is everywhere on here and not just to sell their products but to actually interact with all of us.
  8. Jun 21, 2017 at 2:59 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Something that REALLY helps is a magnetic drill. You can rent them. I'd highly recommend it. We have one (even though ours don't require drilling) but we've let others use it to drill their chassis. Life saver.
  9. Jun 21, 2017 at 3:03 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Step bit for sure. Less wear and tear on a single cutting edge. Buy a few 1/4" bits to start holes if the end of your step bit gets blunt.
  10. Jun 21, 2017 at 3:05 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Ive never had much luck with step bits on thick steel.
  11. Jun 21, 2017 at 3:53 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Lubricating oil is formulated to prevent one piece of steel from wearing away another--cutting fluid (oil) is formulated to help one piece of steel wear away (cut) another -- sulfonated/chlorinated and other additives to assist and encourage wear...
  12. Jun 21, 2017 at 3:56 PM
    Old School
    Old School You are ignoring covfefe by this member.
    Why are you drilling the frame?
    You should be drilling the sliders to line up with the frame holes...
  13. Jun 21, 2017 at 4:03 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Yep, gotta love those step drill bits .... NOT:
    https://www.tacomaworld.com/threads/royally-fd-up-installing-cali-raised-52-led-bar-brackets.491779
    Old School likes this.
  14. Jun 21, 2017 at 4:03 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Sounds like you bought the wrong companies sliders.
  15. Jun 21, 2017 at 4:27 PM
    #35
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Except when it's time to repaint.
  16. Jun 21, 2017 at 4:28 PM
    #36
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If the holes in the frame line up with the mounting plates, I'd go with this... Mark the holes, place the sliders on saw horses, drill away.
  17. Jun 21, 2017 at 4:32 PM
    #37
    tacoRenner
    tacoRenner Well-Known Member
    Sacramento, CA
    '11 Tacoma CrewCab TRD off-road
    I seriously scratch my head over guys who hesitate to weld sliders on, yet drill 32 1/2" holes in their frame. You can weld sliders on, cut them clean off with a sawzall in 5 minutes, spend 20 minutes with a flap wheel, can of flat black spray paint, and no one will ever be able to tell the truck had sliders on it...
  18. Jun 21, 2017 at 4:40 PM
    #38
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Please give up the manufacturer's name you purchased these from. Save others some grief. Me and a buddy bolted on my SOS sliders in a half-hour.
  19. Jun 21, 2017 at 5:29 PM
    #39
    Harry
    Santa Fe NM
    BAMF sliders for one require drilling/bolting if you plan on lifting on a Hi-Lift from the sliders. If you're just using them as light protection from rocks they're not required. Though I'd be curious to see how other no-drill sliders hold up to a Hi-Lift test.
  20. Jun 21, 2017 at 6:58 PM
    #40
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I have bamf and the bolts on only required 6 total holes from the bottom up. Rented a corded drill from harbor freight and used a good bit from lowes then used a step up bit for the rest. Took maybe 1 hr. Kids that fuck this up or use a step up bit in the wrong application is why people think this is hard.
