Drip molding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taijai, Jun 19, 2020.
  1. Jun 19, 2020 at 11:01 AM
    taijai
    taijai [OP] Well-Known Member
    TJ
    New Jersey
    2018 Tacoma TRD Sport Quicksand DCLB (SOLD), 2004 4Runner Sport Edition 4x4
    I will be removing my OEM roof rack and installing new drip molding and clips onto my roof. Do I need any double sided tape or anything like that? Thanks
  2. Jun 19, 2020 at 11:04 AM
    taijai
    TJ
    New Jersey
    Or even some sort of tape to cover the holes? I am waiting on a rack I ordered and will be selling the OEM ones soon
  3. Jun 19, 2020 at 11:06 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Silicone the holes. Use silicone to secure weather strip as well. Or use some 3m double sided tape for weather stripping. Make sure to clean the channels really well with some alcohol.
    Lt. Dangle, taijai[OP] and synaps3 like this.
  4. Jun 19, 2020 at 11:10 AM
    taijai
    TJ
    New Jersey
    Thanks for the tips
    And then just chip out the silicone when I install the new rack?
    synaps3 likes this.
  5. Jun 19, 2020 at 11:12 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Just enough of it to get the bolt started, and then the bolt will push the rest through. Use silicone when you install the new rack too. I didn't with my bajarack and got a leak on the driver's side when it rained heavily. It went away immediately after I caulked it.
    Standard clear silicone from Home Depot is perfect, you don't need anything fancy here. Something like https://www.homedepot.com/p/GE-Adva...CH=REC-_-plpbrowse_multi-_-NA-_-100179996-_-N
    taijai[QUOTED][OP] likes this.
  6. Jun 19, 2020 at 11:13 AM
    Freegolf
    Denver
    You'll be able to rip it off. Cleaning it out of the hole might prove more difficult though. How long before your new rack?
  7. Jun 19, 2020 at 11:18 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I'm thinking if it's just temporary to put some electric tape down over the holes then use silicone once the new rack arrives.
    Freegolf[QUOTED] likes this.
  8. Jun 19, 2020 at 11:20 AM
    taijai
    TJ
    New Jersey
    21 day est. lead time and it’s day 9
  9. Jun 19, 2020 at 11:21 AM
    taijai
    TJ
    New Jersey
    That’s exactly what I thought too but it’s supposed to be a ridiculously rainy week or two here on the east coast
  10. Jun 19, 2020 at 11:22 AM
    Freegolf
    Denver
    Yeah that's what I would do. Silicone doesn't like to adhere to other dried silicone. And it might be hard to get every chunk out.
    taijai[OP] likes this.
  11. Jun 19, 2020 at 12:02 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Clean the area, put down e-tape over the holes, run a bead of silicone around the edge of the tape. Should make it easier to clean off the temporary silicone and keep the threads clean for when the new rack is in.
    Freegolf likes this.
  12. Jun 19, 2020 at 12:05 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Factory just comes with a sticker covering the hole under the weather stripping, so anything more than a sticker should be fine.
  13. Jun 19, 2020 at 12:18 PM
    taijai
    TJ
    New Jersey
    Thanks everyone for the advice!
    I’ll take pics and give updates when the time comes
  14. Jun 19, 2020 at 12:33 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    This is a good point.
    Lt. Dangle[QUOTED] likes this.
