Dripping from under truck - Is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by derickt, Jul 1, 2015.
  1. Jul 1, 2015 at 5:09 PM
    derickt
    derickt [OP] Active Member
    Derick
    Los Angeles
    So after driving with the AC on I've been getting water dripping from underneath the truck. The first point is the passenger side engine compartment area and I was able to see the drainage point - Seems pretty normal. However, I've also noticed that there is water dripping from near the middle (maybe slightly on the passenger side) of the truck. Is this normal?
  2. Jul 1, 2015 at 5:10 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    It might just be me, but I don't see any pic.
  3. Jul 1, 2015 at 5:12 PM
    derickt
    Derick
    Los Angeles
    That's strange, I don't see the pic anymore.... Posted a link though in my original post to the photo
  4. Jul 1, 2015 at 5:15 PM
    awhitfield4
    awhitfield4 Well-Known Member
    Fort Worth, TX
    Mine drips there as well when the A/C runs. Pretty positive its normal and its just where the condensation naturally runs and drips off.
  5. Jul 1, 2015 at 5:22 PM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    This is completely normal the A/C condensation drian is in that location all models and engines. There's a drain hose up there some people modify it so that it doesn't drip onto the frame.
    OP observe closely as I bet you are simply observing the puddle build up from the dripping. Hard to say from just the photo at any rate I would not be concerned could just be extra condensation dripping from other A/C component further back a possibility under the correct ambient conditions.
  6. Jul 1, 2015 at 5:26 PM
    Pigpen
    Dan
    Northwest Montana
    The A/C condenser drain tube terminates directly over the frame. This is probably why you're seeing multiple drip points. Many of us have extended the drain to a lower point, so that there isn't water sitting on that part of the frame year round (A/C compressor runs for defrost too).
  7. Jul 1, 2015 at 5:30 PM
    723rdCAT
    Kentucky
    That makes perfect sense dripping or condensation build up on the frame which would cause drips a little further from the drain point.
  8. Jul 1, 2015 at 5:33 PM
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    Normal. There is no place your truck is (or should be) filled with clear water. I get condensation from the A/C on all my vehicles.
  9. Jul 1, 2015 at 5:39 PM
    Pigpen
    Dan
    Northwest Montana
    I stopped outside NAPA today to admire the nice drip coming from my A/C drain tube. Dog was in the truck, so I left it running (locked) with A/C on. Most people would shake their head in disappointment if they knew what I was so proud of, standing in that parking lot with a smile on my face.
    We're all here 'cause we're not all there...:crazy:
    Flynbyu2 likes this.
  10. Jul 1, 2015 at 5:45 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Every A/C has a drip. Home or car.
  11. Jul 1, 2015 at 5:48 PM
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Nothing wrong there, very common when the A/C is on.
  12. Jul 1, 2015 at 7:07 PM
    SmallWonderTaco
    SmallWonderTaco Well-Known Member
    Joey
    Newark, DE
    2008 Toyota Tacoma TRD Sports
    Toytec 3" lift, 5100 Bilstein suspension all around , AAL, 33" BF Goodrich AllTerrain KO2, front ARB bumper, All pro kick out sliders, ATO skid plates, Safari snorkel, TRD Cai.
    That's normal.
  13. Jul 1, 2015 at 7:23 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    HOLY SHIT. NO.
    I can't see the pic.
