Drive bearing play
Discussion in '1st Gen. Tacomas (1995-2004)' started by newertoy, Aug 30, 2011.
  1. Aug 30, 2011 at 11:32 AM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    How much loosness or play should there be when the drive bracket is loosened. Should you be able to MOVE the bracket 1/2 inch back and forth and up and down?
    Or should it be TIGHT with no movement?
    2003 extra cab 4x4
