Drive by wire question
Discussion in 'Technical Chat' started by JoeN 267, Feb 25, 2010.
  1. Feb 25, 2010 at 6:47 PM
    JoeN 267
    JoeN 267 [OP] Active Member
    Joe
    Central NY
    Tacoma - TRD Sport 2010
    With all the "recalls" going on now, I have seen the phrase "drive by wire", I looked it up to find the meaning, which I now understand, my question: is my gas pedal or brake pedal (see sig for truck info) using this technology ?
  2. Feb 25, 2010 at 7:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yes, gas pedal only
  3. Feb 26, 2010 at 8:01 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I can't imagine we'll ever see "braking by wire". Throttle's run electronically have been around for a long time, and after time, cables will most likely become non-existant.
  4. Mar 1, 2010 at 2:30 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    They use drive by wire in Jets that cost 60,000,000.00
    To use them in vehicles that cost at the most 40,000.00 is stupid
    or am I wrong ?
  5. Mar 3, 2010 at 9:17 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    That'd explain why I managed to chatter the rear tires stopping on dry pavement in a truck which supposedly has 4-wheel ABS.
    As for the electronic throttle, most/all vehicles with electronic traction/stability control systems will have that sort of system since many (if not all) of those systems are at some point programmed to reduce or cut the throttle.
    It's entirely possible that no new car made in the last 5 years which had a sticker price over 12k still has a mechanical throttle control, and also absolutely true that mechanical throttles aren't immune to sticking anyway. High probability that fewer than five members of Congress or officials with enough juice to call a press conference know enough about cars to understand any of that even if it's been explained to them in detail.
    Don't get too spun up over what the politicians are saying or that the gov't seems intent on inciting panic over Toyotas. Literally dozens of people nationwide continue to drive these cars every day and survive.
    SUA issues in Toyotas have been blamed for 34 deaths in 10 years which would mean that's 34 of over 400,000 in that time (total auto deaths appear to have averaged about 42,000 per year in most of the last decade), so if you're going to die in your car you're more than 10,000 times more likely to not have it due to a Toyota accelerating out of control.
  6. Mar 12, 2010 at 8:51 AM
    coehorn1
    coehorn1 Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    I'm currently looking at a Tacoma for sale. What is the first year that Tacomas used drive-by-wire gas pedals?
  7. Mar 12, 2010 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    yeah. I cant remember what its called, but it senses the velocity of the brake peddle application, and basically, give max brakeing in an emergency situation..
  8. Mar 12, 2010 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I found more info on Toyotas site:
    Brake Assist (BA) In emergencies, some drivers, especially inexperienced ones, often panic and do not apply sufficient pressure on the brake pedal. Brake Assist measures the speed and force with which the brake pedal is pushed to determine whether the driver is attempting an emergency stop. If the system determines that is the case, it applies additional brake pressure to allow the driver to take full advantage of the ABS brake system. When the driver intentionally eases up on the brake pedal, the system reduces the amount of assistance it provides. This feature comes with VSC.
  9. Mar 12, 2010 at 9:53 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    What? They use windows and seatbelts in $60 million dollar jets. Is it stupid that they are in vehicles too? Tech almost always trickles down.
    Drive-by-wire makes a lot of things possible that aren't with a mechanical linkage. Controlling engine output for traction control is one of them. Engines can also be made to run more efficiently with higher output through drive-by-wire (secondary throttle butterflies is one example).
  10. Mar 12, 2010 at 9:57 AM
    SManZ
    Fauquier County, VA
    The Tacoma also comes with Electronic Brake-force Distribution. It will distribute brake force depending on load. I couldn't find specifics on it but in general more brake force would go to the rears when loaded vs. not loaded.
  11. Mar 12, 2010 at 10:11 AM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    don't know if toyota uses the system vw has, but vw has a trw abs control module and that thing can have brake by wire. not only sensing brake pedal application speed and force, but the module has an electric pump to apply and hold brakes if needed.
    us drivers are being labeled as sensor inputs, all in the name of emissions. both(drive-by-wire and electronic braking) are pretty solid systems and i'm surprised toyota hasn't narrowed it down to all vehicles with just a software update.
  12. Mar 12, 2010 at 11:52 AM
    bmgreene
    Brian
    L.A. Westside
    Not sure what year they started with it, but there are some indicators and advertised features on a car with will indicate that it's probably got ETC rather than a mechanical cable:
    Traction Control
    Stability Control
    Cruise Control (might be a few models with CC on manual throttles, but the CC won't hold a speed as well)
    Any system which cuts engine power when the brakes are applied
    ABS brakes aren't a direct correlation, but there are some parts common to both systems.
    Just remember that if you're terrified of ETC and living under the delusion that mechanical throttles are somehow immune to getting stuck, then just avoid buying any vehicle with any of the above features. Also, avoid vehicles from Lexus, Infiniti, Acura, Mercedes, BMW, and Audi as they pretty much all have electronic throttles these days.
  13. Mar 13, 2010 at 4:31 AM
    coehorn1
    Thanks for the heads up. Been driving a long time and the missus and I have both owned Toyotas (Camry and pre-Tacoma truck), but neither of us has had expensive vehicles.
    I don't care for microprocessor control in a conventional vehicle. I can't help but wonder if Toyota is experiencing the same thing that Audi went thru years ago.....
  14. Mar 14, 2010 at 11:12 PM
    bmgreene
    Brian
    L.A. Westside
    It's got nothing to do with expensive any more. The Mazda3 Pontiac Vibe, and Ford Focus have electronic throttles, and GM full sized trucks have been using them since at least 2003.
    I don't know the whole market model-by-model, but it may be hard to find any car from any maker in any model year past 2004 which actually has a mechanical throttle control. Also if you're worried about computers running important systems, then you'll probably want to avoid any car with ABS, 2nd-generation airbags, speed-sensitive steering, any sort of traction/stability control or any automatic transmission made since at least the mid 1990s.
    A few models which I can pretty much guarantee don't have critical systems run with computers would include the LeCar, Pinto, Vega, Pacer, Gremlin, and anything without a catalytic converter. If you want something built after 1985 there's always the Trabant (they never updated the design after about 1964 except for some cosmetic changes), as long as you don't mind shaking the car after filling up to mix the 2-stroke oil into the gas tank....
    I'm fairly sure that Toyota is going through what happened to Audi in the '80s, since that whole thing turned out be a collection of driver errors and a TV new broadcast willing to rig a car to behave out of control for their story where no real defect existed.
    Remember several years ago when every third headline had something to do with a shark attack? I don't remember exactly which year it was, but of you were to look at shark attack statistics for the last 10 years you wouldn't be able to tell now because there weren't an unusual number of shark attacks, the media just chose to cover every single one prominently.
  15. Mar 14, 2010 at 11:25 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    For the V6 (5vz-fe) was 2003.
  16. Mar 15, 2010 at 4:14 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If you mean *partial* electronic intervention with the throttle ...
    That would be 2003 - when the early-edition ETCS-i (Electronic Throttle Control Sytem - Intelligent) setup from the first-generation Tundra was added to V6 Tacomas (other than S-Runners).
    This version of ETCS-i still had a mechanical cable linkage from accelerator pedal to the throttle body. It added an accelerator position sensor and a motorized throttle body, so the ECM could monitor the gas pedal and exert limited control over the fuel intake. If the ETCS-i components failed, the Taco was still capable of being driven in a limp mode.
    If you mean *total* electronic intervention with the throttle ...
    That would be 2005 - when the mechanical cable was eliminated.
  17. Mar 15, 2010 at 5:07 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You're wrong. What's stupid is drive by wire on the new forklifts we have at work. Terrible
  18. Mar 15, 2010 at 10:31 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    So could you still rev up the motor from the throttle body?
  19. Mar 16, 2010 at 6:05 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Not sure what you're asking ... ??? ...
    Do you mean "when working in the engine bay, can you still manually manipulate the throttle / accelerator linkage to rev the engine?" If so - yes.
  20. Mar 16, 2010 at 7:40 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Sorry. Yes thats what I meant.. Thanks. :D
