Drive lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PVTacomaTRDPro, Mar 25, 2021.
  1. Mar 25, 2021 at 5:28 AM
    PVTacomaTRDPro
    PVTacomaTRDPro [OP] Member
    Today I noticed the drive lights on my 2017 Tacoma TRD Pro are shutting off when my low beams are turned on. They work properly when only the drive lights are selected. The second I switch to low beams they shut off. I know they are suppose to stay on and the last time I noticed that they were working properly was about 3 weeks ago. What would cause this issue?
  2. Mar 25, 2021 at 5:45 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I was under the impression that driving lights only work when the regular lights low beams are off ....at least what I noticed with my off road .now I’m going to have to double check them lol
    Tripod1404 likes this.
  3. Mar 25, 2021 at 5:48 AM
    PVTacomaTRDPro
    Not sure on the Off Road but the Pro they definitely stay on.
  4. Mar 25, 2021 at 5:54 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    thats not normal
  5. Mar 25, 2021 at 5:56 AM
    Tripod1404
    Tripod1404 Annihilator tripod
  6. Mar 25, 2021 at 5:57 AM
    PVTacomaTRDPro
    Lol well I know that. Looking for possible knowledge of possible causes before I start troubleshooting.
  7. Mar 25, 2021 at 6:00 AM
    PVTacomaTRDPro
    They most certainly do and were on a couple weeks ago. I know that because my grill lights are wired into the DRL lights and they were always on when I had my low beams on. I unplugged them 3 weeks because 1 burned out and when I got my new ones and installed them, they now shut off along with the DRL lights when I turn on my low beams. I am 100% positive.
  8. Mar 25, 2021 at 6:02 AM
    brandon78lusch
    Brandon
    check the fuse. Did you initially tap into a fuse or just the wire harness for the DRL?
  9. Mar 25, 2021 at 6:04 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'd go through all your aftermarket doodads n wiring,,, if not disconnect them.
    My 19 OR dims DRLs when low beams are on,,, but they're definitely on.
    Kev250R and brandon78lusch like this.
  10. Mar 25, 2021 at 6:08 AM
    PVTacomaTRDPro
    Tapped right into the wire. Did not touch that. Just put new lights in. They were from a different company which is the only difference. And like I said they work fine when it is just set to DRL. Trying to figure out what changed. They definitely were on all the time before.
