Drive line angles. Help needed
Discussion in 'Suspension' started by Taco Nation, May 25, 2015.
  1. May 25, 2015 at 9:26 AM
    Taco Nation
    Taco Nation [OP] Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    So I just figured out how much to drop the carrier bearing to get the center u joint angle to 0* after a 3 inch lift. Question is do I really want to drop the carrier bearing 2.4" to creat that 0* center u joint angle. I know the truck didn't come stock with that angle in the center so will it hurt or help to make it zero or should I just aim to get back to stock measurements.
  2. May 25, 2015 at 9:30 AM
    Old School
    Old School You are ignoring covfefe by this member.
  3. May 25, 2015 at 9:43 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I get that the tran output and pinion flange should we parallel but should I create a 0* center u joint angle or should I return the center u joint angle to where it was originally
  4. May 25, 2015 at 10:06 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. May 25, 2015 at 10:34 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So don't drop the carrier bearing 2.4"
  6. May 25, 2015 at 11:06 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So the working angle difference between the second and third u joint is 2* so OME carrier bearing drop should fix it right up
  7. May 25, 2015 at 11:20 AM
    Old School
    Trial and error, some guys use washers as spacers till they hit the right amount.
    Also check your u-joints and carrier for play...
  8. May 25, 2015 at 11:27 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Just ordered OME carrier bearing drop kit. I also need a driveshaft spacer ASAP
