Drive line Clunk/No slip yoke to grease
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12Tacoma24, Apr 5, 2024.
  1. Apr 5, 2024 at 12:07 PM
    12Tacoma24
    12Tacoma24 [OP] Member
    2012 TRD sport
    6112's/5100s
    Been having the driveline clunk for almost two years now trying to trouble shoot. it occurs when accelerating/decelerating/getting back on throttle/incline/decline. sometimes it is mild sometimes it violently shakes the cab on a cold morning. but it occurs at random.
    learned of the slip yoke issues others are experiencing and went to grease the slip yoke after ordering all the necessary parts. climbed under the truck and there was no accordion boot to remove, just solid driveshaft from rear diff to carrier bearing which has a good 1/8 to 1/4" of play which leads me to believe it is the carrier bearings fault or U joints, but the U joints don't move at all and seem solid.
    Going insane trying to fix this if anyone has any ideas I'm down to hear it.
  2. Apr 5, 2024 at 12:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’d probably just replace the center bearing.
    wilcam47 likes this.
  3. Apr 5, 2024 at 12:10 PM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    hearing it now that makes sense. any idea how much paly is allowed in carrier bearing?
  4. Apr 5, 2024 at 12:11 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    A scootch
  5. Apr 5, 2024 at 12:12 PM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    alright. thanks.
    Steves104x4 likes this.
  6. Apr 5, 2024 at 4:41 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    I had a similar clunk but not as bad, carrier bearing replacement eliminated it, I got the spicer bearing from rockauto and it even had Toyota stamped on the rubber section
    DoubleB, Steves104x4 and wilcam47 like this.
  7. Apr 8, 2024 at 7:01 AM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    Update: had driveshaft inspected by a shop. nothing is wrong with it. took a ride with the mechanic, best guess stuck throttle body leading to clunk.
  8. Apr 8, 2024 at 8:57 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Broken leaf spring?
  9. Apr 8, 2024 at 9:11 AM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    U Joints?
  10. Apr 8, 2024 at 11:08 AM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    they came back after having 4 technicians look at it. said to get a new driveshaft.
    Steves104x4[QUOTED] likes this.
  11. Apr 8, 2024 at 3:49 PM
    RandyLahey
    Southwest PA
    2013 sport 6mt
    Or maybe a new u joint or carrier bearing, no need for a new driveshaft
  12. Apr 8, 2024 at 4:04 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Get a new mechanic!
    first off, are you 2WD? Because if you are that would explain why you can’t find a slip yoke on your DS. 2WD have it at the tail housing of the transmission and there for use a different carrier bearing.
    If it’s not axle wrap, or u-joints, then it may be torque converter shudder (can you cancel the symptoms by lightly tapping the brake - just enough to trigger brake switch?) or an issue with vvti actuators
    WOODY2 likes this.
  13. Apr 8, 2024 at 4:16 PM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    yeah been thinking about that
  14. Apr 8, 2024 at 4:18 PM
    12Tacoma24
    2012 TRD sport
    6112's/5100s
    yeah it is the prerunner rwd. I really hope its not TC shudder aint that a nightmare to fix? Ive been looking into vvti all morning too. will check tomorrow for the brake tap.
