Drive line vibes after lift
Discussion in 'Suspension' started by bkmcinty, Mar 11, 2013.
  1. Mar 11, 2013 at 12:18 PM
    bkmcinty
    bkmcinty [OP] Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Ok so I hate to beat a dead horse but it seems like there are quite a few reasons for driveline vibrations after lifting. I had 4" spindles up front with a 2" block in the rear and had absolutely zero vibes. I recently upgraded and added a 2.5" upper coil spring spacer and replaced the 2" block with a 4" block. Now I get vibration when I'm at a dead stop and mash on the gas pedal until around 20 mph. Only when I really get on it do I feel the vibes and have no other issues at any other speeds. I am 2wd pre runner so I'm thinking cb drop? Anything else any of you guys could recommend?? Thanks
  2. Mar 12, 2013 at 11:19 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I see lots of bro lean in that pic! :eek: spacers and blocks too huh? :goingcrazy:
    anyway, start with your carrier bearing. prolly the only way to cure that is to add a washer to it, drive a week, then add another and rinse/repeat until it goes away. the shaft is very sensitive to minor changes in angle, doesnt take much for it to be in tune or out of tune.
    past that, your looking at a 1 piece driveshaft mod.
    everyones truck around here is different with what kind of vibes they end up with apparently. some get fixed, and some just have to live with it. good luck sir.
  3. Mar 12, 2013 at 11:50 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    You can try angled axle shims too.
  4. Mar 12, 2013 at 12:42 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    That pic is when I only had the maxtrac spindles and a two inch block.....I haven't updated my sig yet but yeah I'm gonna try the washers out
  5. Mar 12, 2013 at 12:44 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    And the reason I have spacers and blocks is because I didn't want to spend 2 grand on my lift to drive it on the road......to each their own but my truck rides just fine for me especially coming from diesels with 8"+ of lift
  6. Jun 17, 2013 at 11:16 PM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
  7. Jun 17, 2013 at 11:19 PM
    SWCCBEE
    SWCCBEE So Cal Edition
    Greg
    Santa Rita, GU
    2010 PreRunner, SR5, TRD Sport
    WeatherTech floor liners, In process of Debadge, Leveling kit, Tires, Limo tint, Custom TRD SPORT Decal, "ImMrYo" Rear view lifting bar, Ultra gauge, relocated horn.
    I only put 265/70/17s and a 2" leveling kit now I have a "bro lean" how do I even it out??????
  8. Jun 18, 2013 at 8:58 AM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    add a leaf in the back...your rake must not have been more than 2"...I just placed 5100s on mine and 1.5" leaf in rear and I am about 1" lower in the front where I was about 2" lower in the front before...so I gained 1" in bro lean effect from the lift...also the front will settle a bit after you drive it and it sits for a few days...parking mine nose down on the drive way (putting gravity and weight on the nose) dropped the initial lift height 1" in 2 days...when i first installed I got 3 1/4" lift in front from but it settled in 3 days to about 2" which is nice!
    I am getting slight vibrations at low acceleration though so i OP if you read this, did you ever get a fix for it?
  9. Jun 18, 2013 at 3:16 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Never did figure it out I just live with it but the truck is sold now so no worries
  10. Jun 18, 2013 at 4:47 PM
    SWCCBEE
    Greg
    Santa Rita, GU
    Thanks.
