Drive line vibration between 18-28 mph at factory height
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pikerup, Sep 14, 2010.
  1. Sep 14, 2010 at 5:54 PM
    Pikerup
    Pikerup [OP] Member
    IN
    1995 ext. cab 2.7 4x4
    Stock
    First of all-awesome site! What a knowledge base! I've got a question hopefully someone can answer. I've got a 95.5 2.7 4x4 xtra cab with 122,000 miles on it. After a recent oil change I noticed that the right rear spring was broken so I changed the rear springs and shocks. Soon afterwards I changed the front springs and struts. Kept everything at roughly factory height. After the rear springs I noticed the spline at the rear diff was out about 1 inch further than it had been; I wrote that off as it had been in deeper due to the old sagged suspension. After I did the front end the truck has developed a vibration between 18-28 mph. Feels like it's in the rear. I've tried to find play in the drive shaft and cannot feel any, but still feel it could be a u joint. Also, could it be the carrier bearing? Thanks for any advice on this.
  2. Sep 14, 2010 at 5:55 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
  3. Sep 14, 2010 at 11:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What did you buy for the rear? Was it a replacement spring pack? Curious about where you bought it/who makes it..
    The slip yoke should not have moved that much. An inch is a significant amount and possibly the source of your vib. Makes me wonder if you were sold the correct springs.
    Eye to eye, the 95.5 to 97 tacomas used a shorter spring compared to the 98 to 04 models. I believe the length diff is about 1".
    Do your rear shackles angle significantly past the frame shackle mount? The shackle should be approximately 90 degrees to the end of the spring. Are yours like 45 degrees? Or even less? Are your rear wheels centered in the wheel well?
  4. Sep 15, 2010 at 1:53 PM
    Pikerup
    Pikerup [OP] Member
    IN
    Stock
    Thanks for the reply. The springs are no-name replacments off the internet, however they are 4 leafs replacing 3 leafs. I'll check the shackles out and the other items you've brought up. I agree on the slip yoke-the more I think about it, 1" seems like quite a bit-not sure how much is left in there! I'll get back to you with what I find.
  5. Sep 15, 2010 at 3:47 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are the springs new?
    Here's something you can try.... Put 200lbs of weight in the bed and see if that gets rid of the vibes. If it does....leave the weight in the bed for a few weeks. This will help the springs 'settle' and hopefully after they're settled, the vibes will be gone.
    Spring are always taller (give lift) when they're new and they eventually settle down to where they should be.
  6. Sep 18, 2010 at 8:03 AM
    Pikerup
    Pikerup [OP] Member
    IN
    Stock
    Good idea on the added weight, and I appreciate the help! Turns out the springs are about an inch too long (you hit it right on the head digiratus). I could easily tell by sighting down the bump stop. What I want to avoid is an spring RR. I spoke my my lead tech at work and he suggested just spacing the carrier bearing down 1/8" at a time to try to eliminate the vibration rather than swapping springs again.
    I can live with a slight vibration (this is a fishing and hunting, haul kayaks and mulch on the weekend type truck).
    Is there a danger of keeping these springs and tricking the geometry with spacing the carrier? Will that even work? Based on the pictures below, is there enough of the slip yoke engaged to not cause a problem?
    Again, I really appreciate the input I've recieved from this community!
    I'll throw a few hundred pounds of firewood in it today and see what that does.
  7. Sep 18, 2010 at 1:15 PM
    Janster
    Jandy
    Lancaster, PA
    Who ordered the springs? Is it a situation where you can return the springs to the person who ordered the wrong ones?
    You could try the carrier bearing drop, however, the pictures look pretty good in terms of u-joint angle. I'm halfway thinking the vibes are because the slip yoke is out so far, but that's just a guess.
    If you put weight in the bed and the vibrations are still there - the carrier bearing drop probably won't help.
  8. Sep 18, 2010 at 7:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'll have to side with Janster on this. The vib is very likely a result of the slip yoke position. Under high torque you are putting a lot of pressure on the splines in the yoke. That will even out as your speed increases (steady acceleration).
    From the side view, how do the wheels line up in the wheel wells? Is the tire close to the mud flap? I'm a little concerned about what will happen when you stuff one wheel way into the well.
  9. Sep 19, 2010 at 7:16 AM
    Pikerup
    Pikerup [OP] Member
    IN
    Stock
    unfortunately the springs are from ebay. Based on comments, I'm almost sure they are for a newer model
    The tire is clearly closer to the mud flap by about 1.5"
    I think my best course might be to contact the seller and see if he would make this right.
  10. Sep 19, 2010 at 9:09 AM
    Pikerup
    Pikerup [OP] Member
    IN
    Stock
    In any case, through my recent motivation to improve the old truck, it now has a new washer pump, front oxygen sensor RR'd (WHAT A PIA-everything rotted except the pipe!!), new shocks and springs all around and just got new plugs today!
    Maybe I could just shim the slip yoke forward with a piece of 2x4??:eek:
  11. Sep 20, 2010 at 3:59 AM
    Janster
    Jandy
    Lancaster, PA
    What did the ebay seller advertise the springs as? If he advertised them wrong, then its his/her fault. If they advertised them properly and you ordered the wrong springs - then you might be stuck with them.
    If you're stuck with them, I'd get all the information you can about those springs so you can resell them. Then, buy yourself a proper set of springs.
  12. Sep 20, 2010 at 2:42 PM
    Pikerup
    Pikerup [OP] Member
    IN
    Stock
    The ebay seller has agreed to take them back. They said they are for the regular cab, not the extended cab. However, they will not pay for shipping back since they were advertised for a '95 Tacoma 4x4. I think that is kinda BS but at least I can get a refund on an installed part. Shame on me for not asking. If anyone is looking for these springs and wants to pick them up in IN I cn make them a great deal :p
    Thanks for everyone's help on this!
