Drive Line Vibration - Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flavalk, Mar 17, 2014.
  1. Mar 17, 2014 at 4:09 PM
    flavalk
    flavalk [OP] 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
    I have an bone stock '07 2WD Double Cab PreRunner V6 with 90k on it. Well, about 5k miles ago, it developed the infamous 15-30 mph shake while under power. I read at length here all the speculation why this might happen as well as the bulletin from Toyota addressing this issue. A few thousand miles ago it started getting worse and continued up through 40 mph. I torqued the leaf spring bolts (they were loose as hell) although it made no difference. So, I took it to a shop I trust and ask my guy to check it out. He put it on a lift, put it in gear and ran in up to speed while watching the drive shaft. He said he could see the vibration, so he pulled the rear shaft, had it checked and found it out of balance. He also found a bad U-joint so he replaced them all. Results.....smooth as a babies butt.
    Hope this might help those with a similar problem.
  2. Mar 17, 2014 at 7:38 PM
    BennyTRD
    BennyTRD Active Member
    Sask, Canada
    '11 TRD Sport 4X4
    My dealer decided to replace the whole drive shaft on my '11 as part of the TSB on the rear axle, and it made a considerable difference. The vibrations at 40-60kph are almost completely gone. Still a slight vibe under acceleration but going back in this week to get the rest of the work done.
