Drive line vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redgrom, Feb 28, 2012.
  1. Feb 28, 2012 at 11:40 AM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Hello, I seam to have a new vibration between 30 and 55. It's only under load so don't think it's the front diff again (if that went again the truck will be traded in). I have already had the rear drive shaft rebuilt and I recently lubed the u joints. Have the truck lifted to 2.5 front and rear. No carrier bearing drop yet.
    Any ideas what to check?
    Thanks
  2. Feb 28, 2012 at 11:58 AM
    orangedevil37
    orangedevil37 RedBull
    cincinnati ohio
    2010 Tacoma DC 4x4 SR5
    Check your drive shaft angles and see if they match uP. theres a thread about how to correct this.
  3. Feb 28, 2012 at 12:00 PM
    Redgrom
    Brent
    san clemente
    Thanks! For some reason search and my phone don't play well together.
  4. Feb 29, 2012 at 5:07 PM
    orangedevil37
    cincinnati ohio
  5. Mar 1, 2012 at 6:57 AM
    Redgrom
    Brent
    san clemente
    Yep iPhone issue, found the link when I got home but thanks for providing it!
  6. Mar 1, 2012 at 10:02 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There is a carrier bearing drop and a degree shim for the rear axle. 3 degrees or less is ideal. If not, split the difference between the two rear shafts.
