Drive shaft angles, after swap.....
Discussion in 'Suspension' started by ETaco23, May 15, 2008.
  1. May 15, 2008 at 9:13 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Hey there everyone! I will be getting a Tom Woods drive shaft tomorrow and be installing it this weekend. But Ive been talking to my father, who has had some experience with drive shaft angles and what not. But, Does the new Tom Woods shaft Bring the angles back to spec, and cure my issues, or will it still be off cilter, with the lift on. Or Better Yet, will my Vibe in my carrier bearing, just be tranfered to the tranny or rear transfer case, causing damage there? This is a big issue and would like some help, I dont want to put my new driveshaft in and just be causing a problem somewhere else. Any advise or help appreciated!!!
  2. May 16, 2008 at 6:57 PM
    ETaco23
    Evan
    PNW
    I guess No one can help me... Ok I will just take my chances I geuss, thanks alot TW!:(
  3. May 16, 2008 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Doesnt the TomWoods drive shaft eliminate the carrier bearing? If it does, it shouldnt cause a vib any more. There have been a few people that have had a vibe in the 45-55 mph range after install of the new DS, but Im thinking with proper degree shims in the rear, you should be vibe free. :)
  4. May 17, 2008 at 3:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you order a TW driveshaft - you have to give him specific information of how long you need it. So, if you wanted to get rid of the carrier bearing - you could simply by ordering a shaft long enough to do so.
    Evertaco23: Installing a TW shaft isn't necessarily a cure all. Every truck is different and every situation is different. You may or may not experience vibrations after the TW shaft install. You could experience vibes anywhere in the spectrum (speeds - so to speak). At that point, you can add axle shims to help correct it.
  5. Aug 27, 2009 at 8:11 PM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    so what does one of these DS cost average......
  6. Aug 27, 2009 at 8:23 PM
    ETaco23
    Evan
    PNW
    Dont quite remember what I spent on mine.. I believe it was around 240-280
    But not sure. All I know is that its awsome and I am vibe free!:)
  7. Aug 28, 2009 at 7:51 AM
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    do you have a link to the one you bought? I eliminated bad vibes by getting new rims, but i still have this wierd annoying vibe in my seat.
  8. Aug 28, 2009 at 10:39 AM
    ETaco23
    Evan
    PNW
    Do you have take off shudder? and a vibe at around 30-40?
    If so its probably your drive line/carrier bearing.
    I got the TW standard slip 2 joint, I believe....
    http://www.4xshaft.com/index.html
  9. Aug 28, 2009 at 10:44 AM
    ETaco23
    Evan
    PNW
    If you want to order one, I would just call them up and tell them what you got and your measurements. But make sure that you let them know that us 1st. gens have a smaller flange at one end, I believe it was the diff. end. And its just the Flange to Flange measurement they should need. And the style shaft you want ofcourse...
    I made the mistake of not letting them know that one of the flanges was smaller, and had to ship it back....
  10. Nov 8, 2009 at 7:09 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Hey guys, trying to remove the drive shaft right now and it's not budging. I sprayed it with some penetrating lube but a 14mm wrench isn't cutting it...
  11. Nov 8, 2009 at 7:36 PM
    ETaco23
    Evan
    PNW
    yeah, its kinda hard, But it will pop off.
    It sits in there perty tight, I had to get a big flat head and hammer. getting the screw driver on the seam and hitting it a few times and sooner or later it just popped off.
    (Work both sides of flange)
  12. Nov 8, 2009 at 7:39 PM
    ETaco23
    Evan
    PNW
    Wait! do you have the nuts/bolts off?
