drive shaft balancer.....interesting.
Discussion in 'Suspension' started by tacomaman06, May 28, 2009.
  1. May 28, 2009 at 3:21 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  2. May 28, 2009 at 3:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting....
  3. May 28, 2009 at 3:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Makes sense for what it is. That 'technology' isn't any different than using EQUAL in your tires for wheel balancing.
    I wouldn't consider that as a fix for driveline vibrations due to poor driveline allignment.
  4. May 28, 2009 at 3:31 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    hmm.... $65-$82.
  5. May 28, 2009 at 3:39 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It would suck to get a face full of Mercury when installing if the ruberband broke.:eek:
    The idea is good though.
  6. May 28, 2009 at 3:51 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Seems to me like it would put some strain on the shaft
  7. May 28, 2009 at 11:39 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    someone needs to buy these who has high speed vibes and they need to report. I would but I am broke as of late.
  8. May 29, 2009 at 12:19 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How would you know if your driveshaft needs balancing? Vibrations could be caused by a multitude of things.
  9. May 29, 2009 at 4:27 AM
    Janster
    Jandy
    Lancaster, PA
    Exactly.... The driveshafts are already balanced from the factory.
    So technically - using this product for anything other than an 'out of balance' driveshaft would only hide the original problem.
  10. May 29, 2009 at 8:41 AM
    NJB
    NJB Member
    Colorado
    05 Dbl Cab LB TRD Sport SR5 Tow Pkg.
    This type of device is pretty highly regarded in the motorcycle crowd. They are made for the clutch and flywheel. They are advertised as a cheaper alternative to engine balancing to smooth out a rough running hog. They are recommended by a couple of respected books on increasing V-Twin performance.
  11. May 29, 2009 at 3:21 PM
    Janster
    Jandy
    Lancaster, PA
    Most definately...
    My husband and I just replaced the harmonic balancer on our corvette with an aftermarket unit that's liquid filled (off hand, I don't know what the liquid is).
