Drive Shaft Blew Up!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by richardbui23, Apr 20, 2013.
  1. Apr 20, 2013 at 8:21 PM
    richardbui23
    richardbui23 [OP] That guy
    Richard
    Arlington Texas
    Stacy
    so i had my truck lifted last summer and my trucks driveshaft pretty much just exploded. i've been driving with a rattle and vibration but i figured it was my exhaust because the welding seemed.....sketchy.
    Anyways im sure im not the only one the drive shaft blew up on so how did you guys fix it? how do you keep from this happening again??
    PLEASE HELP!
  2. Apr 20, 2013 at 8:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    well that fucking sucks
    holy shit
  3. Apr 20, 2013 at 8:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That could be your vibration issue
  4. Apr 20, 2013 at 8:27 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    yeah i realize now that this was my vibration and rattling issue lol
  5. Apr 20, 2013 at 8:44 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    You could either order a Tom Woods custom drive shaft and not have to worry about vibe issues and your drive shaft exploding. Or get one from a junkyard and have a driveline shop balance it and change out the u-joints.
  6. Apr 20, 2013 at 8:47 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    if had it balanced from the start do you think this could've been prevented?
  7. Apr 20, 2013 at 8:51 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    mother trucker...hows your transmission?!?
  8. Apr 20, 2013 at 8:54 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    It was balanced. You just need to grease the u-joint more often. Its does not matter how expensive a drive line is if you don't grease the u-joints it will explode.
    So next time you hear a rattle check your u-joints next time.:rolleyes:
  9. Apr 20, 2013 at 9:26 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    05-11 PreRunners have sealed u-joints, no grease zerks I believe.
    But none the less, the noise should have been looked at before hand.
    (not bashing you OP, just sayin)
    How many miles on the truck?
  10. Apr 20, 2013 at 9:29 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    well that blows........had that happen on my old heep. driving them BAM!!!
  11. Apr 20, 2013 at 9:34 PM
    BradyT88
    BradyT88 Well-Known Member
    Always the helpful one...:rolleyes:
    Is the front end of the shaft damaged or was it just the u-joint that broke? If it was just the u-joint that shaft might be salvageable. U-joints are only $20-$30.
    Although looking at the pic, it looks like it broke the u-joint at the tranny and the carrier bearing in the center... I'm surprised both would go at once...
  12. Apr 20, 2013 at 9:35 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    152k
    dang wish i would've known! the transmission was burnin up when i finally got her home (we towed) the smell was fantastic lol
  13. Apr 20, 2013 at 9:36 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    im not too sure it broke during sunset and i was more concerned about getting out of traffic but will check and post more detailed pictures tomorrow
  14. Apr 20, 2013 at 9:45 PM
    BradyT88
    Why was the tranny burning up? Don't want to make you just to conclusions with what I am thinking now, but... You drive line is disconnected so towing should not have affected the transmission...
  15. Apr 20, 2013 at 9:50 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    not sure maybe i was just assuming the smell was the transmission.
  16. Apr 20, 2013 at 9:53 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I'd also recommend that you install some sort of driveshaft loop in the form of a limit strap etc, to prevent the truck from "pogo-ing" if it happens again.
    Not much to do at this point but rebuild it, and keep up on the greasing. :cool:
  17. Apr 20, 2013 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Were you on a trailer? Or was someone dragging you behind them with a tow strap?
    If its the latter, could be your brakes that you we smelling if you were stopping both vehicles with your braking.
  18. Apr 20, 2013 at 10:51 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    You cant buff that out.
  19. Apr 21, 2013 at 10:21 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    [​IMG][​IMG][​IMG]https://sphotos-a.xx.fbcdn.net/hphotos-ash4/376056_10151636957850229_1088502683_n.jpg[​IMG][​IMG]https://sphotos-a.xx.fbcdn.net/hphotos-ash4/408723_10151636957940229_667679490_n.jpg[​IMG][​IMG][​IMG]
  20. Apr 21, 2013 at 10:21 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    My Poor Baby
