Drive Shaft Center Bearing Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andy2675, Aug 9, 2017.
  1. Aug 9, 2017 at 3:49 PM
    Andy2675
    Andy2675 [OP] Active Member
    Andrew
    2011 Double Cab 4x4 Manual
    What kind of mileage did you guys get out of your center bearing? I had a vibration in my driveline from a stop and when I brought it to the local Toyota dealer. They said it was center bearing, Im only at 99k on my 2011. This seems rather early for this to be wearing out, what are some things that can cause this to wear early? Its a DCSB 4x4 with a manual tranny.
  2. Aug 9, 2017 at 5:12 PM
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
  3. Aug 9, 2017 at 5:16 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    On my last 1st gen, I had to replace one at 27k. The present one is at 95k with no issues.
    I don't know if they are the same part for different generations. Toyota is not known for changing parts that can be used for lots of different vehicles.
  4. Aug 9, 2017 at 6:30 PM
    Andy2675
    Andrew
    Well that's rather disappointing to hear lol
  5. Aug 9, 2017 at 7:30 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    09 with 220k on original carrier bearing
    Shark18 likes this.
  6. Aug 10, 2017 at 8:37 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    175k on orig CB
    My old gen 1 made it to like 180k before the rust ate the frame
    Shark18 likes this.
  7. Aug 10, 2017 at 6:22 PM
    Andy2675
    Andrew
    UPDATE: so the dealer has already replaced my CSB, realizing this did not fix the shimmy at low end speeds they found that it was my flywheel. Double edge sword suprise...This truck is already on its second clutch. Ive only had it since 85k and assumed it was the original clutch, apparently not the case. Well when the second clutch was put in the flywheel was not "resurfaced?" Im not sure what that means but they are doing that on the house for the CSB not fixing the probelm. Anyone know what resurfacing a flywheel means?
  8. Aug 10, 2017 at 6:26 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    they are going to machine it to make it smooth again.
  9. Aug 10, 2017 at 6:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hahaha 99K? That's laughable (I laugh because I only think about how shafted I got with mine). Less than 30K here.
  10. Aug 10, 2017 at 6:29 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Did they change the U-joints?
  11. Aug 10, 2017 at 6:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you stock height or lifted?
  12. Aug 10, 2017 at 6:37 PM
    Andy2675
    Andrew
    Yes replaced u joints with the CSB, 2inch level up front 1.5 aal in rear.
  13. Aug 10, 2017 at 6:39 PM
    Andy2675
    Andrew
    30k on clutch or CSB??
  14. Aug 10, 2017 at 6:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How long have you been lifted? Is the shuddering new? I ask because maybe your driveshaft angles are just off and some shims would solve your problem.
    la0d0g likes this.
  15. Aug 10, 2017 at 6:50 PM
    Andy2675
    Andrew
    I have only been lifted since january. So maybe 7k miles
  16. Aug 10, 2017 at 6:54 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    I'm at 140k on my 2011 dcsb
  17. Aug 10, 2017 at 7:16 PM
    Bluesjam
    Bluesjam Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
    Make sure you only use the Toyota part for the center support bearing. Do not use after market.
  18. Aug 10, 2017 at 7:23 PM
    Andy2675
    Andrew
    It's at a Toyota dealership. So I would hope so :D
  19. Aug 11, 2017 at 1:11 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    CSB
