Drive shaft fell off while driving.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Donnye13, Oct 29, 2023.
  1. Oct 30, 2023 at 9:22 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Best route take it to a driveline shop and get everything done ,new u joints,new carrier bearing both with greasable joints,and have them check the balance,DONE.
    joba27n likes this.
  2. Oct 30, 2023 at 9:30 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Early ones had a plug. The plan was to take the plug out grease it with a point and put it back in or throw it away and put a fitting in. Personally I would beat the old joint out I don't think it trashed the drive yoke, may look ugly but probably will work just fine. What does the bolt on piece look like? That joint has been bad for awhile.
  3. Oct 30, 2023 at 12:32 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The joint didn't have a hole... it was a plastic ring. On my 07 it has those on the front diff joints (oem.) Grease escaped out of joints like normal... the plastic rings i assume were there to keep dirt out like the rubber version and had a tiny hole (maybe 2) to let grease escape so they wouldn't break from too much pressure while greasing. Just looked at mine... the rear joints don't look they have them. In the 3rd and 4th picture you can see black rings... one side intact, other side broken.
    edit: looks like the plastic dust caps/rings might have been discontinued years ago due to them being brittle and breaking... https://www.corvetteforum.com/forum...5-spicer-solid-u-joint-cracked-dust-caps.html
    TnShooter[QUOTED] likes this.
