drive shaft fix..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4r_to_taco, Oct 5, 2017.
  1. Oct 5, 2017 at 8:23 PM
    4r_to_taco
    4r_to_taco [OP] Well-Known Member
    florida, east coast
    2006 double cab trd off road
    rear diff breather extension, slotted/cross drilled brakes
    Yes I know there is a TSB for the drive shaft issue with some of these early year trucks. Does anyone have a total price of the parts needed for fixing this? I know price will vary depending on where you source parts from, just trying to get an idea..
  2. Oct 5, 2017 at 8:41 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    not sure about that. not to be out of line, but i have a 1 piece if interested.
  3. Oct 6, 2017 at 4:09 AM
    Drtnap19
    Drtnap19 Well-Known Member
    Bluegrass
    2011 DC Tacoma 4x4
    I too went with a one-piece shaft after trying nearly every vibration fix on TW. $652 later it is smooth as silk. My local drive line shop used all Spicer/Dana flanges & shaft. They balanced the new shaft before I arrived. Only took him 30 minutes to install.
    ChadsPride likes this.
  4. Oct 6, 2017 at 4:41 AM
    4r_to_taco
    florida, east coast
    @Drtnap19
    I dont have a vibration, I have the clunk or hit from behind sensation. But maybe a one piece shaft would fix my problem too..
  5. Oct 6, 2017 at 4:42 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You trying to sell?
  6. Oct 6, 2017 at 5:03 AM
    Drtnap19
    Bluegrass
    2011 DC Tacoma 4x4
    Interesting. The clunk is about the only symptom I didn't have. Good luck as I know how annoying this kinda thing can be.
  7. Oct 6, 2017 at 5:07 AM
    4r_to_taco
    florida, east coast
    annoying is right.. just one more thing to add to the list of necessary replacement and must haves (bed braces from total chaos).
  8. Oct 6, 2017 at 6:24 AM
    Drtnap19
    Bluegrass
    2011 DC Tacoma 4x4
    Is it possible a U-joint is about to fail? I think a two-piece shaft has 4.
  9. Oct 6, 2017 at 7:11 AM
    Mickeydog
    Mickeydog Well-Known Member
    Dave
    West Michigan
    2020 TRD Sport, Cement DCSB
    Pro wheels with 265-70-17 Goodyear UT. Pro skid. Pro tail lights. OEM tailgate power lock.
    If this clunk or hit from behind sensation is when you stop. It's probably the transmission downshifting into 1st.
  10. Oct 6, 2017 at 7:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP are you a 4x4? If so grease your slip joint. Its axle wrap causing the clunk when coming to a stop. If you are a prerunner its the same thing but your slip yoke at the trans.... you can try to lube that slip yoke with grease but its bathed in trans fluid so it will probably get washed away
    gearcruncher and ChadsPride like this.
  11. Oct 6, 2017 at 6:49 PM
    4r_to_taco
    florida, east coast
    Just a prerunner no 4wd, Ill have to crawl under tomorrow weather permitting..
  12. Oct 6, 2017 at 8:18 PM
    rheath08
    Russell
    Bakersfield, CA
    It could be a carrier bearing starting to go out.
  13. Oct 21, 2017 at 5:39 AM
    4r_to_taco
    florida, east coast
    Will a one piece shaft work properly on my 2wd prerunner? seen threads about it for 4wd but havent seen one about 2wd..
  14. Oct 21, 2017 at 12:03 PM
    rheath08
    Russell
    Bakersfield, CA
    No a one piece will not work on the 2wd. The shaft length is way to long on the 2wd.
  15. Oct 21, 2017 at 5:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I disagree. There are many trucks with longer one piece drive shafts on the road.
    ABNFDC likes this.
  16. Oct 21, 2017 at 11:18 PM
    rheath08
    Russell
    Bakersfield, CA
    Yes that is true. But they are 4" or larger aluminum shafts. There is not enough room at the cross member for the carrier bearing. For a 3.5" shaft at the length for the 4x4 witch is 67.5 to 68.5 depending on manual or auto trans, it is close to critical speed.
  17. Oct 22, 2017 at 2:47 AM
    gearcruncher
    Canadain bumper technician
    When you say critical speed , are you talking about whip ?
    Anything over 60 inches has a tendency to whip ?
  18. Oct 22, 2017 at 9:31 AM
    rheath08
    Russell
    Bakersfield, CA
    Every driveshaft has a safe operating speed before it starts to become unstable. It depends on driveshaft length, material it's made out of, u-joints, etc. If your interested in some info check out Spicer web site. They even have a calculator so you can play around with different set-ups.
    4r_to_taco[OP] likes this.
  19. Oct 22, 2017 at 9:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There are lots of old GM trucks and cars with drive shafts in excess ( way longer, some as long as 80 inches ) than 67 - 68 inches. It doesn't have to be aluminum, steel was used for a very very long time with no problems. Some modifications may be required. As for the cross member the single piece shaft will be lower due to the angle and no joint. A double cardan joint may also be needed.... True balance also plays a big role.
    So to say that a single piece drive shaft isn't doable on a 2 wheel drive Tacoma is false.
