Drive shaft grease
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DAS Taco, May 28, 2020.
  1. May 28, 2020 at 5:25 PM
    DAS Taco
    DAS Taco [OP] Well-Known Member
    DAS
    2017 TRD Offroad
    Hi guys, just crawled under my 2017 TRD Offroad to grease the drive shaft and I was surprised to find that you can only grease the front drive shaft...weird, I thought the center and rear will have some way of adding grease to it. I'm i missing anything here ?,thanks
  2. May 28, 2020 at 5:26 PM
    SpeySquatch
    2016 TRD OR DCSB
    Check the transfer case drive shaft to the front steering
    DAS Taco[OP] likes this.
  3. May 28, 2020 at 5:44 PM
    DAS Taco
    DAS
    2017 TRD Offroad
    Thanks but that's still the front area, no ?, I was expecting the rest of the drive shaft links to have them as well
  4. May 28, 2020 at 6:57 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    17 was the time frame for deleting the zerk fitting, there’s only a couple on mine.
    SpeySquatch and DAS Taco[OP] like this.
  5. May 28, 2020 at 6:59 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I believe they changed in 17 to only greaseable fronts. I also believe the 16' had 3 greaseable points.
    I'm like 70/30 sure.
    Mine only has the front anyways.
  6. May 28, 2020 at 7:38 PM
    DAS Taco
    DAS
    2017 TRD Offroad
    Thank you guys
  7. May 28, 2020 at 7:39 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly, the non-zerk ones last longer. Most people either over or under greased the factory ones prior.
    Toyota even updated the parts for the 05-16 to be non-zerk as well.
  8. May 28, 2020 at 7:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yep just the 2 up front.
