drive shaft greasing question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauai808boy, Apr 20, 2011.
  1. Apr 20, 2011 at 4:38 PM
    kauai808boy
    kauai808boy [OP] Active Member
    icon/fox 3inch lift, flow-master super 40, jba shorty headers
    hi i have a 2007 extra cab tacoma 4wd off road and decide to grease my drive shaft and i only found 3 grease zerks 1 in the front 1 in the middle and 3rd at the end of the drive shaft and each zerk is located on all three yolks
    i have the chilton repair manual and the pic on where to grease the drive shaft doesn't even look like the one on my truck
    so my question is there any other spots on the drive shaft other than the 3 i just did or anywere else on the truck that has too be greased?
  2. Apr 20, 2011 at 4:40 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    There are two on the front drive shaft at each u joint.
  3. Apr 20, 2011 at 4:51 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    2WD has sealed with zero zerks - no need to grease your shaft
    Prerunner has three zerk points
    4WD has five. Total of 5 should be the same for all the 4x4 models, regardless of cab size. On the rear there are three and they are on the outside of the u-joints. On the front there are two and they are inside the u-joints. Easy to locate as you can rotate your shaft. The bitch to reach is the rear zerk on the front prop shaft. It requires the removal of the heat shield to get to the zerk fitting.
    Hope that helps.
