Drive Shaft Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BIG MoFukin SERG, Aug 23, 2010.
  1. Aug 23, 2010 at 11:52 PM
    BIG MoFukin SERG
    BIG MoFukin SERG [OP] Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    I have an '09 DC TRD OR Taco that started leaking about 2 weeks ago...I noticed the leak was where the drive shaft meets the tranny...took it to the dealer and they told me my drive shaft was bad and they replaced it...they even gave me a complimentary car wash...gotta love the 60 months / 60,000 mile warranty....feels good to get your truck fixed for FREE!
  2. Aug 24, 2010 at 7:20 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    How does a drive shaft leak? It's just a hunk of metal, no fluid in it. Are you sure it wasn't the tranny seal?
  3. Aug 24, 2010 at 7:33 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  4. Aug 24, 2010 at 7:36 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    if you take the driveshaft out some fluid will leak. I don't think the driveshaft was bad like the two above said, maybe not seated right.
  5. Aug 24, 2010 at 7:36 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    it was probably leaking from the tranny onto the drive shaft...
  6. Aug 24, 2010 at 7:53 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I just hope they put in the updated seal when they changed the drive shaft.
  7. Aug 24, 2010 at 11:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is it fixed??
    If yes...then Good to hear - then we don't need to try and guess what it was.
    Do you have 4WD?? If yes...then call up the dumb-asses at the dealership and tell them the driveshaft will never meet up with the transmission. It's called a TRANSFER CASE
  8. Aug 24, 2010 at 1:14 PM
    BIG MoFukin SERG
    Serg
    Los Angeles
    The leak was where the drive shaft joined the tranny, therefor it was mostlikely tranny fluid that was leaking...probably just a bad seal....my truck is 2WD...they took care of the issue though...I could've fixed it myself but decided to let the dealer deal with it since it was under warranty.
  9. Aug 24, 2010 at 2:11 PM
    Asgard
  10. Aug 24, 2010 at 3:29 PM
    BIG MoFukin SERG
    Serg
    Los Angeles
    Yeah i think it was the same issue...instead of only changing out the seal, they replaced my drive shaft as well.
  11. Aug 24, 2010 at 3:29 PM
    LVTacoma
    LVTacoma Well-Known Member
    <--- had same problem, $7 seal from Toyota, 15min fix with a friend.
    either a bad bell seal or not seated correctly. It will leak a bit if its backed out too much
