Drive Shaft Lube Points 2nd Gen 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Jun 18, 2012.
  1. Jun 18, 2012 at 9:06 AM
    moondeath
    moondeath [OP] Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Just lubed the chassis today, but the only zerks are for the u joints. I only count 5 from front to back. Is there no way to lube the slide yolks without taking the boots off? Owners manual says to lube slide yolks with moly. Doesn't make any sense to me that they would say to lube it and not have any way to do it. Truck is a 2011 TRD OffRoad 4WD Access Cab. Heres some pictures. Any input will be appreciated.
    Also, I have the typical thump/bump when I stop and/or start to go. Its been doing that since around the time I bought it new.
    ***Just an FYI, I now have a DCLB 4wd and the lube points are the same as the Access Cab 4wd.***
    **I reloaded these pics. I'm pretty sure they are in the right order. The only ones I'm not positive about would be the 'front differential' and the 'rear transfer case' photos.**
    Front differential
    Front of transfer case ( cant see the zerk from this angle)
    Rear of transfer case
    After carrier bearing
    Rear differential
    abk1004, AlCapwn, Ahhhh and 7 others like this.
  2. Jun 18, 2012 at 11:57 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  3. Jun 18, 2012 at 12:08 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I count 5 in your pictures as well :)
  4. Jun 18, 2012 at 2:07 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I grease those same spots. I have also dropped the rear part of the rear driveshaft and re-greased the slip yoke with Molykote. Solved the thump for a while and needs to be re-done whenever I feel motivated again.
    FenrytheTaco likes this.
  5. Jun 18, 2012 at 3:34 PM
    moondeath
    Pa, Gardners
    How many miles do you usually have to go between dropping your driveshaft? Seems strange Toyota didn't just put grease fittings on there. It almost seems that mine didn't have enough lube from the get go considering its been thumping from almost new.
  6. Jun 18, 2012 at 4:13 PM
    bigmooze
    Richard
    Belle River, ON
    It's strange and frustrating, but easy enough to look after yourself. I'll have to look at my records for the exact distance between re-lubes, but I can tell you that after only 16,000 km (ish) I had a new driveshaft installed under warranty. A second on came some time after (same thumping slip yoke issue), and here we are today, after one re-grease on the third driveshaft.
    I just ease into the gas pedal to prevent jolting the drivetrain, just in case. Helps with avoiding racing off the line ;)
  7. Jun 18, 2012 at 4:32 PM
    moondeath
    Pa, Gardners
    Thanks for your input. I will have to look into this.
  8. Jun 18, 2012 at 5:33 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    i havent been able to get to either of the ones on the front shaft yet :-/
  9. Jun 18, 2012 at 5:46 PM
    moondeath
    Pa, Gardners
    They are a pain. You can rotate the shaft by hand to the position you need. I used a grease gun with a flexible tube. The grease fitting that is closer to the transfer case is easier to get to by removing the small heat shield that is in the way.
    TRDSport10 likes this.
  10. Aug 26, 2015 at 1:36 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Great advice, too bad my heat shield bolts are rusted in. Pointing the zerk to the driver's side was my only work around.
  11. Aug 26, 2015 at 4:57 PM
    moondeath
    Pa, Gardners
    Spray the bolts with PB blaster or some penetrating fluid and let it sit a day or 2. Try to break them loose. If that doesn't do it, then heat them up with a torch at crack them loose.
    After that put antiseize on them and all bolts that you remove to prevent them form corroding.
  12. Aug 26, 2015 at 5:08 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    If the bolts on his are anything like the ones on my exhaust there is no cure for the amount of rust.
    hinmo24t and Alexely999 like this.
  13. Aug 26, 2015 at 6:31 PM
    moondeath
    Pa, Gardners
    There's always a way to get rusted bolts off.
    a400ryan likes this.
  14. Aug 26, 2015 at 7:18 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Is that amsoil grease?
    Jon
  15. Aug 27, 2015 at 12:22 AM
    Hartford
    Maine
    2011 Acc Cab 5spd
    Oh I know, but mine would require destruction.
  16. Aug 27, 2015 at 3:30 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Mine required a new frame. That reminds me, I should get some milk of magnesia on those bolts this weekend.
  17. Aug 27, 2015 at 1:44 PM
    ziggynagy
    Stoughton, MA
    Great advice! I don't have a torch, slowly building up my tool collection. I'm at the point where i'll need a small shed soon (a garage would be better).
  18. Oct 20, 2015 at 4:39 PM
    Torgo
    Torgo New Member
    Devon
    Austin, TX
    12 I4 Manual 4x4
    Since I spent some time looking for the missing "fifth" zerk on my regular cab, I just want to leave this here in the event someone else runs across it: the regular cab has a 1-piece drive shaft, not a 2-piece, so there's no carrier bearing and no extra u-joint.
    So you'll find only 4 if you have a regular cab. Ignore the picture showing the carrier bearing, and the other pictures all provide good references.
  19. Oct 20, 2015 at 5:46 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I got 65K on mine if the boot shows no leaks of grease it still should have all the grease it needs where is it going to go? The older ones had a grease fitting but no boot.
  20. Oct 20, 2015 at 6:45 PM
    moondeath
    Pa, Gardners
    Correct. If the seal is good on the slip joint, no need to worry about it. However, some people have had issues with the slip joint binding up due to lack of grease from the factory. In which case the metal band needs cut off and the shaft dropped to grease it. I guess toyota didn't put a grease fitting at the slip joint so as to avoid people over filling the slip joint and causing hydro lock. Breaking the drive shaft.
