Drive Shaft lube ?????
Discussion in 'Performance and Tuning' started by brutalguyracing, Jan 24, 2010.
  1. Jan 24, 2010 at 9:17 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    i am going to lube my drive shaft tuesday?
    anything special i should use
    all i have is like reg grease or all purpose grease thats in my gun...
    also is there anything else that should be greased while im under there???
  2. Jan 25, 2010 at 8:58 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  3. Jan 25, 2010 at 9:01 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I bought a tube of Mobil1 sythetic and did mine a few weeks ago.
    Its quite a messy job too. 5 joints to do. The two on the front driveshaft were a pain in the ass to tighten the fitting to the zerk
  4. Jan 25, 2010 at 9:21 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I was wondering the same thing yesterday since I changed my oil at 15,000 miles. The manual recommended greasing the "propeller shaft". I assume that is the driveshaft?
    Other than the 2 driveshaft fittings, what else needs to get lubricated? Should I use OEM Toyota grease or is Mobil 1, etc okay too?
  5. Jan 25, 2010 at 9:31 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
