drive shaft ping
Discussion in '1st Gen. Tacomas (1995-2004)' started by MarkC, Apr 13, 2007.
  1. Apr 13, 2007 at 6:27 PM
    MarkC
    MarkC [OP] Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    when i go from park to rev. or drive somthing under there PINGS VERY loud. any ideas, i'm thinkin tranny mount or loose bolts under there..??
  2. Apr 14, 2007 at 8:23 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey Mark, I have heard something about this a while back, if I can remember correctly it had something to do with the universal joints, they need to be greased and you also have to purge all the old grease out of them. check with your local dealer there might be a TSB on this.
  3. Jul 24, 2019 at 7:07 PM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    U joint is about to go. Or that’s what happened to me. Pinging sound started, within 2 weeks u joint broke on the freeway.
  4. Jul 25, 2019 at 3:49 AM
    1997tacomav6
    Denver
  5. Jul 25, 2019 at 5:46 AM
    J $
    J $ Active Member
    Jared
    04 Silver Taco 4x4, 3.4L V6, TRD Extracab
    That would be very bad!!
