Drive shaft play rotational play
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CO_0321er, Mar 16, 2017.
  1. Mar 16, 2017 at 8:20 PM
    CO_0321er
    CO_0321er [OP] Well-Known Member
    thank you for the intelligent response. First of all, I understand everything you are saying, and Im hoping thats the case (no issues), but why do some trucks have slop like mine and others are tight? I have a few friends who are helping me diagnose this as well, and their tacomas have no rotational play. again, i understand what you are saying, but just concerned that some trucks are tight with little slop, and some like mine that seem to be well worn down.
    thank you again for that long post :thumbsup:
  2. Mar 16, 2017 at 8:21 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    well said, ty
    CO_0321er[OP] likes this.
  3. Mar 16, 2017 at 8:34 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Could be set up to the loose side of tolerance. Could be worn.
    At the TC side there is a lot of moving parts until you hit the immovable one which most likely is the parking pin in the transmission (auto) or until all of the slop between each gear is taken up in a stick. So many possibilities to guess at. So either completely rebuild the rear end and the TC if it bothers you so much or wait until you actually have an issue.
    Realistically until you repair your carrier bearing and all of the joints who knows if the clunk was those or the TC or rear end. I would fix the obvious, drive the truck and forget about it until it it appears again.
    CO_0321er[QUOTED][OP] likes this.
  4. Mar 17, 2017 at 2:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is normal. The reason is backlash or commonly known as lash. This is due to the clearance between the teeth in the gears. If they were tight it would not last very long, and it would damage the gears. What you described sounds about right.
    https://www.quora.com/What-is-the-backlash-in-gears-How-is-it-advantageous-or-disadvantageous
    https://www.youtube.com/watch?v=r0NsMzdFcZg
  5. Mar 17, 2017 at 9:57 AM
    CO_0321er
    I'm just confused as to why some tacos have no play and some do. You'd think if they need space then all of them would have play.
  6. Mar 17, 2017 at 1:14 PM
    Exracer2
    Colchester Ontario
    Two motors built to the same tolerances will NEVER make the same HP or torque. Small differences will cause this to be so.
    Same with gears, TC’s, transmissions and so on. It is part and parcel of mass production and even hand built one off’s will be the same. So either accept it as the way it is or make yourself crazy trying to wrap your head around it.
    Years ago a friend was racing in a super sport class that had very restrictive rules regarding modifications. He said he could get cylinder heads from the junk yard and the best to the worst of STOCK cylinder heads had a 20% difference in flow. These all were stock unmodified. At the same time I would build my motors to one end of the spec on different areas to maximize HP. Built right to the specs you can get differing results.
    One last example. At work we rebuild a machine and two parts go together perfectly. The next exact same machine and we have to modify one part or another to make it assemble correctly. All of the parts are within spec but if one part is to the tighter tolerance in one dimension and another mating part is to the looser tolerance they either have slop or are very tight. So we either swap parts around until they all work well or modify one or another to make it work. If we send the part for re-inspection it come back as within tolerance. So we can fight and fight or just make it work. That is likely what is the case with your truck. Either through wear or the mating of parts with combinations that are at differing ends of tolerances yours has some slop.
    So either spend the money to start rebuilding something that may be perfectly fine or leave it alone. Your call. But by continually asking the same question after it has been addressed many times already in your own thread you will chase away anyone who might reply and explain it to you. I know I have given just about as comprehensive an explanation as I can come up with to explain it to you. I really can’t say anything that hasn’t been said already. So your understanding of the issue comes down to you and not the information or explanation at this point. Read. Read it again. Read it some more. Goggle it. Google it again.
    Now my last effort at explaining it to you is this:
    https://www.amazon.com/Differential...4/ref=tmm_pap_title_0?_encoding=UTF8&qid=&sr=
    sparkystaco likes this.
  7. Mar 17, 2017 at 1:18 PM
    CO_0321er
    Thanks bro. I was just trying to get some solid info and assurance I'm not about to blow my diff up. Thanks for the detailed responses.
  8. Mar 17, 2017 at 1:24 PM
    Exracer2
    Colchester Ontario
    Just drive it. If after the DS fixes it still has issues then take it one step at a time. When we diagnose things at work we make an assessment and replace one part at a time. Unless other parts are 100% fubar’d they are left alone.
  9. Apr 20, 2017 at 7:08 AM
    tjstoner
    tjstoner Well-Known Member
    Travis
    Arkansas
    Stock
    Having the exact same issue in my truck from what you describe. 2001 tacoma with 120,000 miles. I had the ujoints checked last week and came across the warn out carrier bearing. We got the carrier bearing changed monday but the problem still exist. Does anyone have anything else I need to check besides the carrier bearing and ujoints?
  10. Apr 22, 2017 at 12:50 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Read this thread, all of it. There is good information to be had here.
    Short answer - It is normal backlash between the gears.
  11. Apr 22, 2017 at 10:35 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    These trucks seem too have a lot of backlash,mine has it also and it causes the truck too clunk in mine when at speed either letting off or applying the gas.I talked too Toyota about it and they wont do anything about as they say its normal,which they always say.
  12. Apr 23, 2017 at 8:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is because it is normal. I have been driving stick shifts since I was 14 years old. I am now 62 years old every vehicle I have ever driven has backlash in the drive train enough to make a "clunk" sound. Some you can hear and feel more than others. It is normal.
  13. Apr 23, 2017 at 9:43 PM
    lynlan1819
    Tacoma
    Lifted
    That depends on how much backlash you have,no truck or car for that matter should have so much lash that it clunk's,its a sign that your pinion gear is more worn than it should be.
  14. Apr 24, 2017 at 1:24 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Normal.
    You are entitled to your opinion. It also depends on your definition of what a "clunk" is. It also doesn't have to be tied to wear of a pinion gear. You could cause a huge clunk or slop simply by setting the lash too loose in the differential which would in turn cause excessive wear of the gear sets.
    Take any standard shift vehicle. Park it on level ground so that it doesn't have weight on the differential and crawl under and move the drive shaft by hand.
  15. Apr 24, 2017 at 5:43 AM
    #35
    lynlan1819
    Tacoma
    Lifted
    My truck is an automatic.Took it too a pro driveline shop and the said the truck has way more backlash than it should have.And since jimmy posted that he is 62,if you want too know I am 55,age has nothing too do with having more knowledge than say a guy that's 25.
  16. Apr 24, 2017 at 5:43 AM
    #36
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    You should hear my manual tranny drive line lash holy hell o_O
    BassAckwards likes this.
  17. Apr 24, 2017 at 6:04 AM
    #37
    lynlan1819
    Tacoma
    Lifted
    Lol,just saying Toyota could do a lot better job of putting the Tacoma rear ends together.
  18. Apr 24, 2017 at 6:19 AM
    #38
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    every stick I drove in past 30 years has clunked to some degree, autos do it too depending on the shift and my taco dos it when going to 5th at times if I let off the throttle a bit
  19. Oct 17, 2021 at 6:45 AM
    #39
    woodychaps
    woodychaps New Member
    greggo
    Mine clunks when I switch directions and apply the brakes. I'm not sure if that is what you are experiencing but thought I would throw it out there, I think my issue is brake related but does sound like a metal on metal coupling clunk of some sort.
  20. Oct 17, 2021 at 7:51 AM
    #40
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If it didn't have that play it would be an issue
