drive shaft slip yoke Oetiker clamp size?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raylo, May 2, 2022.
  1. May 2, 2022 at 6:51 AM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Getting around to some maintenance, and at 125,000 miles I have never lubed my DS slip yoke. Not clunking, and I know some will say it is sealed and good for life. Maybe. I also know you can use hose clamps or zip ties on the boot. But I have the Oetiker tools and if I can find a clamp I'd like to do that way. Anyone know what size we need?
  2. May 2, 2022 at 8:54 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I lubed mine up with the proper PTFE lube awhile back just cus. If i remember correctly the Oetiker clamps had their sizes stamped on them. I was able to remove them without too much damage to them with intentions to put them back on, tried but couldn't. Put 2 zip ties on the end of the bellow that i removed to lube everything with full intentions to buy the right sized clamp.
    Just now realized with your thread I haven't bought a replacement clamp and the zip ties are still doing just fine 40k miles later (I lube the rear ujoints every oil change so I check em).
