Drive shaft Specs
Discussion in 'Technical Chat' started by Torspd, Jun 25, 2010.
  1. Jun 25, 2010 at 8:42 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So here is the deal. My carrier bearing went out yesterday. I had it towed to Toyota to make sure there wasn't anything else wrong, as far as possibly the pinion gear. Toyota called me back with a quote of just under $1600 for a new drive shaft. Pfff.
    I called Tom Woods custom driveshafts and they said I need to get the dimensions of the stock one and center to center measurements of the bolts on the trans., and the 3rd member. I know there are quite a few member here that have them so I figured this would be the best place to ask.
    I have an '06 4.0 Access Cab. No short bed.
    Thanks for the help all. If I can give them the specs today they can have it to me by Thursday.
  2. Jun 25, 2010 at 9:13 AM
    Torspd
    Tor
    The Great America!
    Also, I know it makes a difference. My truck is 4x4.
  3. Jun 25, 2010 at 10:05 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    you shouldnt need a whole new driveshaft if its just your carrier bearing that went bad
  4. Jun 25, 2010 at 10:10 AM
    Torspd
    Tor
    The Great America!
    I'll have to talk with them again. I know where you are coming from though. I have a feeling that a bit more is messed up than the carrier. To much Tq probably.....
    I thought that the carrier wasn't a replaceable part though. I'm not sure. Is it something that is just pressed on?
  5. Jun 25, 2010 at 10:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    See Service manual below - carrier bearing replacement & parts
  6. Jun 25, 2010 at 10:21 AM
    Torspd
    Tor
    The Great America!
    Hmmm....dude. Thanks. seems that they are trying to give me the run around. That hepls a ton!
    One piece would still be nice, but a bearing is a heck of a lot cheaper.
