Drive shaft squeaks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bassinbeam, Aug 10, 2017.
  1. Aug 10, 2017 at 6:32 PM
    Bassinbeam
    Bassinbeam [OP] Member
    Keiran
    2005 white Tacoma TRD
    so as I'm either going slowly up a hill or start to accelerate at low speeds my driveshaft squeaks, and as everyone here can relate we all love our tacomas so hearing an abnormal noise really pisses me off and annoys me. I found that it's coming from the rear yoke if I'm using vocab right, but it's coming from the yoke that attaches to the diff. Do I need to replace the whole thing or shoul I get a new bearing kit. The zyrk is broken and if you look up into the hole there is some metal that shifted over the hole a little bit
  2. Aug 10, 2017 at 6:37 PM
    Pigpen
    Dan
    Northwest Montana
    The yoke or the last U joint? The U joint is where the grease zerk is. Sounds like a bad U joint. Have all 3 replaced if you're doing one.
    ABNFDC and mynewtoy like this.
  3. Aug 10, 2017 at 8:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes. Universal Joints, if you do one do all three. If it is squeaking it is dry and could come apart which you don't want to do at highway speed.
