Drive shaft support bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toybuck, Nov 27, 2023.
  1. Nov 27, 2023 at 7:37 PM
    Toybuck
    Toybuck [OP] Member
    Bt
    None
    Ok guys I have replaced 4 drive shaft support bearing. This year. How do I solve this problem? Any ideas?
  2. Nov 27, 2023 at 7:45 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    What part have you been using?
  3. Nov 27, 2023 at 8:09 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    211750-1X is a Spicer part that is essentially a Toyota OEM part, even has a Toyota part number stamped into it- as best I know it’s still the case, may have changed
    Chances are if your burning them up you’ve got other reasons contributing- either too much angle from the driveshaft putting stress on it, or what I’ve noticed, if you shim the carrier bearing down it throws off the angle and burns them up faster
  4. Nov 27, 2023 at 10:10 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I would think too much lift.....or rear axle wrap...
    what's the condition of your rear leaf's and shackles ...
    has the truck been lifted..
    AT or MT....what's the condition of the transmission mount?
    Any chance your motor mounts are shot...
    How many miles on it....
    that carrier has slight adjustability ....where did that slot end up....are you right in the middle of it at mid-way...
    sdk1968 likes this.
  5. Nov 28, 2023 at 12:01 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    How are you installing them? Following the correct torque procedure in the FSM, etc? There is also a section about aligning the carrier bearing to be perpendicular to the DS- have you checked that?
    sdk1968 likes this.
  6. Feb 5, 2024 at 5:51 AM
    Toybuck
    Toybuck [OP] Member
    Bt
    None
    Ok guys. Springs are good motor, mounts are good. Alignment is good. Drive shaft angle might off. But what is the correct angle. The truck dose have a lift installed befor I got it.
    The cardan joint is not real smooth. Help please
