Drive shaft to rear diff casing gap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nemesis-dsl, Dec 14, 2024.
  1. Dec 14, 2024 at 3:49 PM
    Nemesis-dsl
    Nemesis-dsl [OP] Well-Known Member
    21 Trd Sport.
    Is this small
    Gap normal
    Between t where the drive shaft and rear diff casing? Look like 1/4”
    heard it’s Norma to allow the slip to move. But I got a diff whine and seeing if that could be causing it
  2. Dec 14, 2024 at 4:54 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    Yes that's normal and no it doesn't slip in and out. That's a shield for the seal inside.
    Chew likes this.
  3. Dec 14, 2024 at 5:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    Slip is on the transmission end
    Your pinion cap appears fine and the seal must be good with no lube slung around anywhere.
    Chew likes this.
  4. Dec 14, 2024 at 9:49 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If the whine is between a slight acceleration or deceleration, it is normal. I put on bigger MT tires and the noise went away. Well, due to the tires I can't hear it anymore at least. I had the same problem with a Chevy K2500.
    BUZZCUT likes this.
  5. Dec 15, 2024 at 8:58 AM
    Nemesis-dsl
    21 Trd Sport.
    Thanks everyone.
    Toycoma2021 likes this.
