Drive shaft u joint zerk fitting size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badhand2, Feb 10, 2017.
  1. Feb 10, 2017 at 12:32 PM
    badhand2
    badhand2 [OP] Well-Known Member
    utah
    2021 tacoma trd off road access cab
    I have a 2012 4x4 ext cab does anybody know what size zerk fittings are on the front drive shaft?Thanks to all that reply.
  2. Feb 10, 2017 at 1:53 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I used the needle attachment and it worked great. Use it and also a small hose.
  3. Feb 10, 2017 at 1:56 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I was not aware that there are different sizes of zerks. All 5 of mine on the driveshafts are the same size.
    Alexely999 likes this.
  4. Feb 10, 2017 at 2:14 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    standard?
    I believe they 1/4"
  5. Feb 10, 2017 at 2:42 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you replacing the grease zerks on the truck or are you having issues getting the gun to fit on the zerk? If the problem is the latter every grease gun I have used could be adjusted (bigger or smaller) by turning the grease fitting on the end of the grease gun.
