drive shaft u-joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by esse10, Sep 1, 2015.
  1. Sep 1, 2015 at 11:57 AM
    esse10
    esse10 [OP] Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Question for u folks that have replaced the u joints before. Are the U joints suppose to be a little snug or free play after you first install them to the shaft. How do you get them to loosen up a little? will it damage them If you install them a little snug or little tight? any passed experience on that? here is a picture of what i'm talking about.
  2. Sep 1, 2015 at 12:12 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    according to the picture you posted, your u-joint has a wee bit more free play than most
    DrFunker likes this.
  3. Sep 1, 2015 at 1:07 PM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I replaced all three myself using a vice and a bf hammer. they will be very tight then they will loosen up, just install the shaft and don't worry
  4. Sep 1, 2015 at 1:09 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Nice
  5. Sep 1, 2015 at 1:11 PM
    ndmak
    ndmak Well-Known Member
    did the same as topcathr and one was pretty tight, the other two were moderately tight. I pulled the caps off and put grease on my finger and smeared it, and then greased them after install
  6. Sep 1, 2015 at 1:18 PM
    Wack
    Wack Well-Known Member
    G
    Phoenix, Az.
    2015 TRD 4x4
    After you get the U joints together hit the yokes with a hammer and they will loosen up. It will settle the caps in the yokes.
  7. Sep 2, 2015 at 2:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They should be nice and snug to tight ( still able to move them smoothly by hand ).
    TACO TX likes this.
  8. Sep 2, 2015 at 3:56 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I just replaced a couple of mine. The joints were snug for sure which is fine. I need to redo or replace my front one again with another new one. Not sure if I got a bad joint or just screwed it up putting it in. It's a little loose when I grab it under the truck. I can feel some vibes from it in the floorboard still.
  9. Sep 2, 2015 at 6:28 AM
    esse10
    Texas
    Okay thanks guys I feel much better about it after hearing a few opinions on how they should be
    a little stiff during install.
  10. Sep 2, 2015 at 8:11 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I replaced all mine last year and some were fairly "free" and one or two were pretty tight. They felt smooth, though, and so it seemed ok. What I think is a snug fit is not close to what the drive shaft thinks is snug.
  11. Sep 2, 2015 at 8:20 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    As long as they are smooth, and you don't feel any rough or gritty feeling then they should be good to go. A 2 jaw puller and a cut off wheel makes removal a snap. A 6" C-clamp to reinstall.
  12. Sep 3, 2015 at 5:26 AM
    esse10
    Texas
    Ok, thanks guys. I hammered them out but using a vice to install. They're a little stiff but feel smooth, I'm gonna go with that..........I love this place lots of knowledgeable folks willing to help out.
