DRIVE SHAFT vibration solutions <4" rear lifts
Discussion in 'Suspension' started by ndcmack, Jun 19, 2013.
DRIVE SHAFT vibration = What fixed it!
  1. shims
    0 vote(s)
    0.0%
  2. shims + CB drop
    2 vote(s)
    12.5%
  3. Cb drop
    10 vote(s)
    62.5%
  4. 1 Piece Drive shaft
    1 vote(s)
    6.3%
  5. 1 Piece Drive Shaft w/ Double Cardan
    0 vote(s)
    0.0%
  6. 2 piece Drive shaft w/ Double Cardan
    1 vote(s)
    6.3%
  7. Other
    2 vote(s)
    12.5%
  1. Jun 19, 2013 at 7:02 PM
    ndcmack
    ndcmack [OP] Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    Just as stated, lets Poll what fixed your driveshaft vibrations. Also comment on how much lift you have(What setup you're running) in the rear and what worked for you.
    You should also state what truck you have... DCSB, DCLB etc.
  2. Jun 20, 2013 at 5:37 PM
    ndcmack
    NICK
    Western Washington
    Not enough
    No one wants to contribute to sharing solutions we all seem to be searching for?...It's discussed so often
  3. Jun 21, 2013 at 7:54 PM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I measured the input angle of the driveshaft in the rear diff, and measured the angle coming out of the tranny. They were almost identical, so I measured the two shaft angles and they were substantially different. I added washers to the center bracket, dropping it till the two angles were very close to each other, I don't remember the exact amount. Tested every few washers till my vibes were gone. Then measured the washers and had a steel block of equal thickness fabbed. Have an AP Expo pack and Bilsteins.
  4. Jun 21, 2013 at 8:53 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    Wyoming
    2012 TRD Off Road Double Cab V6 6Speed
    Can you tell me what thickness that block is you had made :D ? I'm running the same rear setup
    I've got 3* shims in right now and really don't have any vibes at all besides a small takeoff vibe. Not solved yet but i'm content with the way it is for now.
  5. Jun 22, 2013 at 5:36 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I have the Toytec ultimate lift with 5100s, includes the add a leaf and wedges. I needed roughly 1-1/4" inches to get my shafts nearly aligned. Tough for me as my loads vary from week to week in the summertime and I see the vibe move around the speedo.
    It does pay to check the torque on the u-bolts after a few months, which does help get rid of some of the vibes.
  6. Jun 23, 2013 at 7:04 AM
    mrw3685
    TX by way of KS
    08 Prerunner TRD
  7. Jun 23, 2013 at 7:08 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    I like the idea of a poll, much easier than reading through a thousand posts.
    :thumbsup:
    I will contribute when I do my lift
  8. Jun 24, 2013 at 10:26 PM
    ndcmack
    NICK
    Western Washington
    Not enough
    Agreed! Updated.
  9. Jun 24, 2013 at 11:13 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    does anyone REALLY get rid of the vibe? i feel like its just a matter of getting it to a point you can live with, in all honesty.
  10. Jun 25, 2013 at 2:55 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I had vibes before my lift. The lift actually cured mine. Dakar's with just a carrier bearing drop is all I have. No shims.
  11. Jun 25, 2013 at 3:08 PM
    coseng
    coseng Well-Known Member
    Grove City, PA
    2011 TRD DC
    OME 885x front, Dakars rear, LR UCAs, ECGS bushing
    ...this...
    I have three degree shims and a beefed carrier drop. Almost no vibes...
  12. Jun 25, 2013 at 3:12 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    96 FZJ80
    OME, ARB, TJM
    I had take off shudder, 18-22mph shudder, and 55-60mph vibes. I flipped my carrier bearing 180*. Took away the 18-22 and the 55-60. I still have the take off shudder though. I just deal with it. I have recently developed a 25-30 vibe that is very light. I havent really tried to chase it down though, so I'm not sure what it is. I am hoping its just tires.
    DCSB-885coils up front, 1.5"aal added to a tsb 4 leaf pack. With my shell I got about 2" of lift from it.
  13. Jul 1, 2013 at 8:05 AM
    SconnieHailer
    Marc
    Wyoming
    I got rid of my 3* shims two days ago and then just dropped the Carrier Bearing ~3/4" and now no vibes! I have the AP expo pack...
