Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Mar 7, 2014 at 12:09 PM
    #421
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Sounds like a tire balance issue. Take it in to America's Tire and have them balance the tires.
    I know, sounds too simple. But if the person who balanced them before didn't use the proper adaptor, they'll be out of balance. Personal experience speaking (I had the exact same shake).
  2. Mar 7, 2014 at 12:09 PM
    #422
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Just went out and pulled up on both tie rods and nothing. Raised the truck shook the wheels no play. Let it back down rocked the truck from front to back by grabbing the tires and rocking them and nothing a minor clicking noise when coming back forward. Went and grabbed my neighbors brand z 71 same click so guessing that's normal. I'm dumbfounded how if it is driveline how it causing my steering wheel to shake
  3. Mar 7, 2014 at 12:14 PM
    #423
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Have done that. Had 4 new sets of tires put on in the last month and one new set of wheels tried. Still did it. Road forced balanced by discount tire several times. Nothing.
  4. Mar 7, 2014 at 7:46 PM
    #424
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I think I got it!!!! I really really think I got it. lol I took out the 8mm spacer on the cb and took it all the way back up to stock. Keep in mind I have a 6 in lift. The vibes were better but still there. So I put a washer in drove it almost there. put in another washer and 99% gone. Decided either I got really lucky or I found the fix. So 3mm spacer is to come.
  5. Mar 8, 2014 at 8:38 AM
    #425
    bbj0227
    bbj0227 New Member
    Georgia
    2013 Stock Tacoma
    2013 Sr5 Stock truck. Gone rounds with Toyota dealer,national, and regional. After National said they would do nothing, I could file lemon law, arbitration, talk to a lawyer or all 3 at same time. I initiated lemon law on their side and the next day I get a call from regional(Southeast Toyota Finance) who offered to repair using TSB SU1301. Upon pickup, vehicle has same vibration. Thought it was the "Dunflop" tires. At a tire dealer that I was trying to road force balance the tires, they test drove it and the mechanic looked at the driveshaft while back end was jacked up. His opinion and observation was that the driveshaft was wobbling at the transmission and he also thought I had Torque Converter chatter. I have an arbitration hearing Tuesday. We'll see how it goes.
  6. Mar 8, 2014 at 9:10 AM
    #426
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    On a 2013? Geez.
  7. Mar 8, 2014 at 9:47 AM
    #427
    Osugoose
    Osugoose Well-Known Member
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    885x w/ nitro sports,Dakars w/ 182,Katskinz two tone leather
    Definitely sounds like you are on the right track, that rear lift (blocks I'm assuming) means that you are inducing more axle wrap, so the pinion is rotating to a higher angle during driving, the first shaft needs to match the pinion angle during normal operation. So dropping the shaft even slightly at the cb makes all the difference in the world.
  8. Mar 8, 2014 at 9:48 AM
    #428
    Osugoose
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    Good luck man
  9. Mar 22, 2014 at 7:57 AM
    #429
    Mach375
    Weirdest thing. Driving down the freeway and blew a quarter-sized hole in the boot that covers the slip-joint.
    Since many of you have done a single piece shaft conversion, and may still have the old two-piece laying around, would anyone mind shipping the slip-joint boot and clamps to me?
    Thanks!
  10. Mar 22, 2014 at 8:17 AM
    #430
    Mach375
    Someone may or may not have been driving a one-digit truck at or near three-digit speeds :anonymous:
    That, and I had installed a grease fitting sometime back. My indication something was up was about a half a cup of grease all over the underside of the rear half of the truck.
  11. Mar 22, 2014 at 8:21 AM
    #431
    Mach375
    No, but I suspect it's going to be one of those things I can't get ala carte, and have to buy the whole DS.
  12. Mar 25, 2014 at 4:00 AM
    #432
    Mach375
    As I suspected, the boot does not have a separate part number. Took my parts guy at Toyota a while to find it in the diagrams. So now I'm hoping someone who swapped out for a one-piece DS will still have their old one sitting around and be willing to ship me just the boot and clamps...?...
  13. Mar 25, 2014 at 4:03 AM
    #433
    Mach375
  14. Mar 25, 2014 at 4:04 AM
    #434
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Once it warms I will do this
  15. Mar 25, 2014 at 4:33 AM
    #435
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
  16. Mar 25, 2014 at 6:54 AM
    #436
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    sub'd
  17. Mar 26, 2014 at 7:47 AM
    #437
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    It's axle wrap, not a harmonics issue, save your bucks...
  18. Mar 27, 2014 at 6:37 AM
    #438
    Osugoose
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    Agree with doording here, call a driveshaft shop, even if they aren't local, those parts should ship cheap. You will have to provide them dimensions though for them to match.
  19. Mar 27, 2014 at 7:02 AM
    #439
    Osugoose
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    I would think for a 2-piece driveshaft, a balancer on the 1st shaft near the carrier bearing would be much more helpful. Adding mass to the first shaft would help calm it down and keep the carrier bearing and crossmember from bouncing around so much.
    The problem I see with our shafts is that the first shaft is too short and /or light, it doesn't have enough moment and mass to keep it stable. Adding a balancer to the end could help. When I look at it, I think the unanchored shaft (second shaft) should have the least moment and mass in the system, toyota/spicer just didn't design it that way. I would love someone from one of those to companies to chime in and tell me what they think though.
  20. Mar 27, 2014 at 11:19 AM
    #440
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    I get a vibration around 50 and up and it seems like the noise is a rolling noise going from nothing to its peak all within a second or 2. I first suspected the drive shaft but was also thinking maybe one of the rims is slighty bent I got it second hand so I dunno really. What's the easiest way to tell if it's the driveshaft making the noise ? 2005 tacoma prerunner access cab
