Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Mar 30, 2017 at 12:41 PM
    #601
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    One piece drive shaft group buy @ramonortiz55
    Bruce988jl and DrFunker[QUOTED] like this.
  2. Mar 30, 2017 at 1:34 PM
    #602
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    The washers you added are on the wrong side of the CSB. They need to be between the CSB and the crossmember.
    Bruce988jl likes this.
  3. Mar 30, 2017 at 1:42 PM
    #603
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Lol there is a single in between. The bottom one u see is a lock washer
  4. Mar 31, 2017 at 2:25 AM
    #604
    DrFunker
    DrFunker Well-Known Member
    Texoma[QUOTED] likes this.
  5. Apr 10, 2017 at 11:52 AM
    #605
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    Well... I had vibration on hard acceleration from stop, if feels like the drive shaft bounces up and down. About a year ago Toyota had the truck for few weeks, changed engine mounts, 4 leaves pack, something in the steering wheel, angled the pinion whatever. Then the vibration went away.
    1 month ago I started having vibration while decelerating from 35-15 mph heavier at 20mph.
    Took it to the dealer, adjusted the pinion angle.
    Guess what? The old good vibration came back :mad::eek::annoyed:
    I even told them to check the history of vibration before touching anything.
    They will have to truck to work on it next week.
  6. May 1, 2017 at 6:32 PM
    #606
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    mine all of sudden has vibration at about 80. and this past trip yesterday and friday was having it at about 75. its kinda wierd becouse it didnt do it before. nothing changed unless 4 section bed cover removal did that?
  7. May 5, 2017 at 5:43 AM
    #607
    Nalex
    Dealer have been messing with the truck for few weeks now. Added shims to the leaves as well. Still vibrates :mad:
  8. May 5, 2017 at 12:45 PM
    #608
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I'd be willing to bet lunch on them not even using an angle finder on it. They're just playing darts in the dark.
  9. May 5, 2017 at 3:45 PM
    #609
    Nalex
    They called me today. The service manager I am dealing with is really nice and at least acknowledging the problem and not saying it s normal. Toyota is sending a tech middle of this month, they said he ll be working on it. So let's wait and see.
  10. Jun 17, 2017 at 6:42 PM
    #610
    samson12693
    samson12693 Member
    Samson
    2007 White Tacoma TRD OR 4x4 DC
    Bushwacker Fenders, Toyota Roof Rack, NFAB Rails... Next tires rims, 5100's springs.... in my lifetime Supercharger :)
    i have read through this and it seems that when i think i got it... i get confused again... bought the HF angle tool. Per the first post following directions and pictures Page 1 I got (front drive shaft at 1.30)( rear Drive at .70 )and (axle .90). Dont know what to do with those numbers.
    Secondly, read about the pinion and tc flange... ok used a flat bar wrench etc followed directions got 0 because of calibration then 2.10 at the rear axle flange. put on rear drive shaft 0.00 calibration then moved to front drive shaft by the CB and got 2.10. I dont know what to do with those numbers. I replaced the u jont at the TC and the center one (already replaced the one at the rear axle all with in 2-10k miles of each other.) i have a vibration/ weird feeling in my seat from 50 thru 65 and somewhere in between. I do not low speed issues and driving 75+ no really issue just had the tires balanced but hell that doesn't mean anything.
    I need a cliff and a way to drive the truck off it jumping out right before so i can watch it smash into the ground lol
    v6 4x4 DC auto factory trd off road with 265 75 16 A/T rf10 new frame at 95000 i have 126k now
    thank you for any help and you guys are great !
  11. Jun 23, 2017 at 6:54 PM
    #611
    3djedi
    3djedi Active Member
    I just added fox 2.5 coilovers and 2.0 rear shocks with Dakar leafspring. I get a vibration between maybe 18-25mph. I've measured the angles and the diff to TC is off .3 degrees in the positive direction. The driveshafts were off by about 1.5 degrees even with the OME CB spacer. To get it closer to zero seems like I would have to add a lot of drop. Do you guys think the CB is the source of the vibs?
  12. Jul 6, 2017 at 7:53 PM
    #612
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Has anybody ever used a carrier bearing like this? I installed a DMZ Long travel kit last year and had the driveshaft modified with a slip joint as well as adding this carrier bearing. I also had the driveshaft modified with a slip joint as well as adding this carrier bearing mount. I did all the work myself except balancing the driveshaft, so I am in unfamiliar territory. I had a pretty minimal vibration and didn't think much of it. Then I regeared this year with a 5.29 ring and Pinion and now my vibration is increasingly horrible. Starts at about 50 mph like a high frequency harmonic vibration resonating through out the cab and then gets worse from there. The vibration occurs going down a hill in neutral or in Drive going up a hill. I have the truck up on jackstands right now and I can even replicate it that way as well. I am dying for some advice on what to do. Help please!
    Edit: tranny and pinion are parallel. Carrier bearing is about 0.5 degrees above straight line.
    Bobcdn likes this.
  13. Jul 30, 2017 at 5:02 PM
    #613
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  14. Jul 30, 2017 at 7:40 PM
    #614
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Problem solved. Got rid of the solid aluminum carrier bearing mount and replaced it with a Dana/Spicer type carrier bearing that has rubber surrounding the bearing. Vibration has resolved. In short do not buy carrier bearings without some sort of rubber dampening.
  15. Jul 31, 2017 at 3:10 AM
    #615
    DrFunker
    Do you happen to have any pictures of what you installed? Thanks.
  16. Jul 31, 2017 at 5:57 AM
    #616
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Dana/Spicer brand $26
    It doesn't work however on pre runners without an added slip joint on the rear of the driveline. Also I had to fab a little bit for the mounting.
    Bobcdn and DrFunker[QUOTED] like this.
  17. Jul 31, 2017 at 5:59 AM
    #617
    DrFunker
    Thank you.
  18. Jul 31, 2017 at 6:07 AM
    #618
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I must read
  19. Jul 31, 2017 at 7:57 AM
    #619
    Silver2015
    Silver2015 New Member
    2015 Tacoma SR5
    Hello All,
    In the process of trying to fix a driveline vibration in a bone stock 2015 Prerunner SR5. I notice the vibration at 50 MPH and then it continues from there.
    Assuming the dealer won't be much help... Where should I start? I was thinking about doing the spacer on the carrier bearing. Would I need the leaf-spring shims too?
    Any other thoughts/suggestions?
    I appreciate it!
  20. Jul 31, 2017 at 8:06 AM
    #620
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Look for worn parts first, u joints, center bearing, trans mount, leaf springs, u bolt torque. Then move on to drive shaft angles. Measure first off, don't just throw stuff at it that might work. Also, grease those u joints, if they are the greasable kind. There is a TSB from the dealer for this. They replace the trans mount with one the sets the trans slightly lower, then they may do a few other things to get it in spec as well.
    DrFunker likes this.
