Drive Shaft Vibrations Solved Step-by-Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TscotR214, Oct 18, 2012.
  1. Oct 8, 2017 at 5:38 AM
    #641
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    I took the carrier bearing drop spacers off. I think they’re more for 2-4 inch lifts. If anyone wants them I’ll be glad to mail them to you if you’ll pay the shipping. I have $25 in them.
    Don’t remember who said it but smaller square shims is all I needed and it seemed to make it much smoother.
  2. Oct 8, 2017 at 5:52 AM
    #642
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
  3. Oct 8, 2017 at 6:57 PM
    #643
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Just installed my LT rear. Guess I know what I'm doing next weekend
  4. Oct 18, 2017 at 11:28 AM
    #644
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    Thanks Scot ! Great post!
    I will get the wixey gauge, shims and washers soon! but first I want to be sure if (having no lift kits installed) should I fix leaf springs or replace shock absorber first? check pics and video and let me know....by the way I bought the act 2 months ago!
    Thanks
    https://www.youtube.com/watch?v=In7-l7FvR7I
  5. Oct 27, 2017 at 3:12 PM
    #645
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I haven't lifted my truck yet, but is it worth measuring my current angles on there before I lift?
    Would the stock angles benefit anyone?
    hammertaco11 likes this.
  6. Oct 27, 2017 at 3:16 PM
    #646
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Yes, measure angles before. Also measure your before lift heights.
    If you have no vibes now and can get the same angles back after lift you should be vibe free post lift.
    303tacoma likes this.
  7. Dec 28, 2017 at 9:12 AM
    #647
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    So I finished up the install of the new IEDS bearing and U-joints last night. Assembly went together well and I used the mounting design @MonkeyProof came up with in an attempt to create the proper drive line angles.
    It was an attempt though, I now have a vibration at 15-20 mph and 35 +\- a few mph that fades away and a slight hum at anything over. The way I understand it, I need to add spacing for the carrier bearing to get better angles.
    I measured the driveline the best I could using the technique @TscotR214 wrote up in this thread and found my angle to be 1.9 degrees at the flange for the transfer case and 8.3 degrees at the differential. So a difference of 6.4 degrees. I believe these are supposed to be < 3 degrees but wanted to confirm?
    When I started this project, I had 2.2 degrees at the transfer case flange and 7.7 degrees at the diff. I found this interesting due to starting the spacer at 1 3/8” as @MonkeyProof did expecting this to be a decent starting point. I added a 1/8” washer after in an attempt to fix the vibration but ran out of threads for the bolt.
  8. Dec 28, 2017 at 12:02 PM
    #648
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Looks like you measured wrong the angles. Need more info to calculate.
  9. Dec 28, 2017 at 2:02 PM
    #649
    desertjunkie760
    Shane
    Check My Sig.
    Was that directed towards me?
  10. Dec 28, 2017 at 2:15 PM
    #650
    Dacon
    Danny
    Gilbert, Arizona.
    Yes. Your values are off the chart which means you measured wrong or you jumped the truck in the Grand Canyon. You missed to measure the middle U-join angles and calculate.
  11. Dec 28, 2017 at 3:09 PM
    #651
    desertjunkie760
    Shane
    Check My Sig.
    I fail to see where I’m supposed to measure at the U-joint in the OP. I’ll retake measurements with the new shims and post them up. What am I calculating exactly?
  12. Dec 28, 2017 at 4:08 PM
    #652
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    This is awesome information. Thanks O P and all how added to it! :thumbsup:
  13. Dec 30, 2017 at 2:12 AM
    #653
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    I was talking with a tech with Spc alignment, he said with a carrier bearing ( i have a double cab long bed), your angle in back of the carrier bearing should be equal but opposite of the angle of the differential. He said no need to measure from transfer case to carrier bearing.
  14. Dec 30, 2017 at 10:02 AM
    #654
    Dacon
    Danny
    Gilbert, Arizona.
    Then how you going to find the working angle of the U-joint at CB?
    BlueFalconActual likes this.
  15. Dec 30, 2017 at 10:50 AM
    #655
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
  16. Dec 30, 2017 at 12:35 PM
    #656
    Clay7160
    I asked him, he said that’s not needed, because the angle from the transfer case to the carrier bearing does not ever change it’s fixed, And you need to cancel out the angles that you created by lifting or lowering
  17. Dec 30, 2017 at 3:33 PM
    #657
    Clay7160
    The tech SPC also said a good rule of thumb is 1° Of shim for every inch of lift. My long bed seems like it’s lower in the rear by about an inch than the short beds at the dealership, and the Leaf springs are flat or almost in a negative arch already with 112 Miles
  18. Jan 14, 2018 at 5:44 AM
    #658
    tacoma guy
    Joe
    Phoenix Az.
    OK so after reading throw this thread and meny like it over and over and over again is it safe to conclude that the take off shutter is coming from the carrier bearing angel not being right ? I don't have any vibration. Just the take off shutter at 5 hmp. It is smooth as glass the rest of the time. I only have a 1in lift in the rear plus an half inch do to the thickness of my 8 leave spring. I just want to correct the take off shutter. I did do a 1/4in spacer on the carrier bearing and didn't really do much. Let me add that taking the lift out made the take off shutter alot better but still there ever so slite at times. Any advice on correcting that ?
  19. Feb 8, 2018 at 2:12 PM
    #659
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
  20. Feb 14, 2018 at 5:18 PM
    #660
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    So I installed an OME 3" lift and LR UCAs. I also have a CB drop kit installed. Post lift I have a constant small vibration. I only feel it through the pedal and no where else. Here's my driveline angles. I assume the angles are relative to 90 degrees so I listed what my angle finder said and the difference between that and 90 degrees.
    Should I shim the rear axle or doing anything at all with shimming? Or is my vibration coming from something else and all these numbers look fine? Thank you.
